Author Topic: Any Nordic users out there?  (Read 6536 times)
saint_chuck
« on: July 30, 2006, 12:20:21 pm »
I note a LOT of dealers promoting their line of tubs in here. Any non-dealer have any experience with the Nordic tubs made in Grand Rapids, MI??? The Pools Plus shop here used to carry them, but not anymore.....ANyone know why?
All they carry now is the HS and "others" made by HS.
Mendocino101
Re: Any Nordic users out there?
« Reply #1 on: July 30, 2006, 03:43:35 pm »
Nordic spas are very good value spas.....they are simple but effective and most can be bought for under 5 grand....many models offer a 5 year no fault titanium heater much the same as the bigger makers use in their spas along with Gecko controls....If you are looking for something with not a lot of frills but made with very good components than Nordic is worth a look.......
saint_chuck
« Reply #2 on: July 30, 2006, 04:08:32 pm »
Thanks Mendocino (Homer for Senate, eh?)
I toured the factory in Grand Rapids and met many of the people as they were building these tubs. They clamp and glue all of their connections, and also water/pressure test all of their builds before shipping. Same components that go in the HS spas. Also, they put a plastic floor under the tub to prevent ants/pests.
Am I missing something? I am having difficulty rationalizing why HS is 4 grand more....
Mendocino101
« Reply #3 on: July 30, 2006, 04:31:33 pm »
lol.....well.....I am sure HS would think so.....no I just think if you want a simple spa that is well made than they are a good choice....again not a lot of frills but solid components and a well thought-out spa at a good price....open seating if you like that instead of the more contoured.....
« Last Edit: July 30, 2006, 04:33:04 pm by Mendocino101 »
scott10367
  • I live to spa and spa to live!
« Reply #4 on: July 31, 2006, 12:31:27 pm »
Hi, I would HIGHLY reccommend that you wet test that Nordic.  While they told you they use the same compenents as HS, that is simply not true!! Here are just a few obvious differences:
The foam is about 70% on Nordic versus 100% Hot Spring.
scott10367
« Reply #5 on: July 31, 2006, 12:41:04 pm »
Sorry about that, here are more differences:
1.  The pumps are NOT as strong!! Just feel one wet and running.  The Nordic feels like a garden hose, except for the whirlpool which is really strong.
2.  The Nordic is louder.  Wet test them both one right after the other...it is obvious!
3.  The lighting in Nordic stinks...on or off...no dimming which I hate.
4.  When wet testing the Nordic, and I have used 2 different ones wet, the benches are so narrow I could not get comfortable.  I admit I am a bigger guy, but even my wife fell off the bench.
5. The Nordic does cost more to operate as it uses a two-speed pump to circulate the water.  The pump is also alot louder than the circ pump on the HS, Sundance, or Artesian Spas.
6.  You mentioned the bottom on the Nordic.  Ask them to tip one up and feel that plastic.  Then have someone tip up a HS and try to pound into the bottom...huge difference!  Even the Great Lakes has a much better bottom than Nordic.
7. The claim that they use the exact same compenents is just so wrong its sad.  They use one 35 sq filter, where HS will have alot of filters so you clean them less. ANd the Tri-X filter is totally unique to HS like the Micro-Clean is to Sundance...also a great spa btw.
In conclussion, if you want to save money up front for a boring basic spa then Nordic is for you.  If you want an actual massage...try HS wet, try Sundance wet, try the new Caspian from TR wet (even though you disliked the Bengal), try a few other brands wet before you buy...then you will make a good decision.
Good luck!
Mendocino101
« Reply #6 on: July 31, 2006, 01:29:06 pm »
Scott,
I am not going to get into a pi$$ing contest with you but I think you views are way off base.....I do not think it was ever the intent of Nordic to compete head to head with the Hot Springs or Sundances of the world but to offer a quality but affordable alternative..... the simple fact is they do use components that as are good as any in the in the industry, If you can please explain the real and tangible benefit of the Hot Springs "5 year no fault titanium heater and that in the Nordic that uses a 5 year no fault titanium heater, it would be appreciated or the difference in the Gecko controls and those that are in the the D-1 line or the Artisans spas again it would be appreciated .....The shell can take a beating like just about no other and they are not loud to operate ....That claim of everyone who loves to tout a circ pump and it being quiet while a 2 speed pump is loud is about as bogus as saying "Vito" from the Sopranos is now a slender man because he lost a 100lbs NO ! hes now just 100lbs overweight instead of 200....A circ pump is quieter than the 2 speed pump no question but both I and customers still have to open the spa to see of our two speed pumps are running, the argument is a false one when it is implied that the 2 speed pump is obnoxiously loud.....That said a wet test is the best way to find what works for a person and if any spa someone is interested in is the spa that works for them.
« Last Edit: July 31, 2006, 08:37:51 pm by Mendocino101 »
The_real_Clown_Shoes
« Reply #7 on: July 31, 2006, 08:43:51 pm »
Nordic insulation is just not there.  I have limited experience with them, but ask your dealer to do a few things.
Ask them to kick the cabinet, then do the same thing to a Hot Spring.
Ask them to pound the shell on a dry model, then do the same on a Hot Spring.
Both times the Nordic usually sounds like a bass drum in a cave.  There are several reasons the Hot Spring cost more money, but ask your local Hot Spring dealer to take the time and explain the differences to you.
If you are looking for a Hot Spring line comparable to the Nordics, try out the Hot Spot.
« Reply #8 on: July 31, 2006, 08:47:38 pm »
Just want to mention that from the Pools Plus people I have met at various conferences, etc. they've all been very friendly and knowledgeable.
I would also recommend that you stop by Zager's.  Very nice people there as well.  They're a Dimension One dealer.
Mendocino101
« Reply #9 on: July 31, 2006, 09:19:10 pm »
I am not sure what the point of the above post is.....but if you want to pound on something, than take hammer to the Hot springs spas and than the Nordics and see what holds up better.....interesting as no answer to the component statements......but this whole thread is almost comical as it is not really comparable products but they are not meant to really compare....I am unsure as to why so many HS people want to try and defend or justify things when there is no need ....Please go back and read the whole post.....I think at its core the poster did not understand why the Nordics are 4000 grand less....I said hey they are nice and a good value but not a lot of frills but they do use very good components .....than you have someone making irresponsible posts about them not using such components and that is a bold lie....Do I think they are as good overall as Hot Springs ?...NO..... Do I think if you want something for under $5000.00 and still have it made well are they worth considering ? you betcha .....I think the Escape premium which has 44 jets and 2 pumps is terrific value at under 5000.00 grand...I do not think you will find many of the major makers to offer its equal for the price....but its not intended to directly compare with a Hot Springs or a Sundance or a Marquis.....its meant to be reliable and affordable for those who want something simple but still with quality.
« Last Edit: August 01, 2006, 12:11:59 pm by Mendocino101 »
fatman
« Reply #10 on: August 01, 2006, 09:59:52 am »
Thanks for keeping this thread in the proper perspective Mendo. The original post never asked for a dealers battle/argument. You continue to be a real benefit to this forum.
Mendocino101
« Reply #11 on: August 01, 2006, 01:12:15 pm »
Thank you for the kind words Fatman...... :D
scott10367
« Reply #12 on: August 01, 2006, 02:49:46 pm »
Hey, I didn't mean to kick off a fire storm about my opinions regarding HS, Sundance, Artesian versus Nordic.  The reason I got into the exact differences between them was for another post also by the original guy who siad that Nordic told him (implied?) that Nordic was basically a HS without a Moto-Massage.  I should have kept my comments to that post apparantly.
If you want you can find his other post under round verus square spas which I believe Medicino also replied to.  I am wondering based on your vigourous defense of Nordic and your attacks on HS dealers if you are a Nordic rep or dealer?  Just curious.
Mendocino101
« Reply #13 on: August 01, 2006, 05:55:05 pm »
Attack on Hot Springs....You are joking I assume ....I have never attacked Hot Springs nor would I.....I will say this some Hot Springs people at times strike me as being "Arctic" like in their defense at something that might be seen as anything less than complimentary about the product ......Also you must have ex-ray vision to read that someone from Nordic was telling someone it was basically a Hot Springs with out a moto massage.....How did you read that or did you consult with lady Cleo and she was able to twist what was said into that.....I very plainly read that the person happen to see the Nordic plant and came away impressed and was trying to understand what made the Hot Springs that he also looked at 4000 grand more.....My reply if you read was just that they are a no frills spa but they do use very good components to which you said no they do not ....I than asked you to explain the differences in the heaters as example which as of yet you have not done....bottom line for me is Hot Springs is a very well made product that that is also well supported....Nordic is a spa that has less frills.....perhaps less eye appeal and is simple but they do use very good component's in the spa and that for the dollar are a good value.....If you read something more into than that....than start guessing weights with the carney's because you have a gift most do not.....
« Reply #14 on: August 01, 2006, 07:48:00 pm »
Please remember that your wallet will take a much bigger "kick" and "pounding" when purchasing a HotSpring when compared to Nordic also! ;)
The question wasn't "which is better"... It was suggested by Mendo that this is a "value" spa and at NO point did he suggest otherwise so I'm unclear how it progressed to this?
Stop reading between the lines you guys and take posts at face value. If you don't understand something...ASK! Mendo will always fully explain himself and won't hide anything. Try that instead of attacking. Remember that respect is earned and Mendo has earned his on here!
I would still like to see Mendo's questions answered Scott. Opinions are one thing but backing up statement with FACTS are something entirely different. The fact remain that many manufacturers use similar componants in many aspects.
« Last Edit: August 01, 2006, 07:49:22 pm by Steve »
