Author Topic: What would you do (when to drain)?  (Read 1987 times)
cooltoy2000
  • Go Flames Go!!!
« on: July 27, 2006, 04:00:47 pm »
I am going away for a week at the end of August. I was also going to change the water about the same time.
Should I:
A. Drain the tub before I leave and leave it empty for the week.
B. Follow the normal pre/post vacation procedure and drain after I come back.
C. Do not add any chemicals (have an ozonator) before leaving and then change the water after.
Thanks for any help.
Brookenstein
Re: What would you do (when to drain)?
« Reply #1 on: July 27, 2006, 04:17:01 pm »
I vote for B.
cooltoy2000
  • Go Flames Go!!!
« Reply #2 on: July 27, 2006, 04:22:41 pm »
B for Bush? ;D
The_real_Clown_Shoes
« Reply #3 on: July 27, 2006, 04:44:33 pm »
Drain and refill before you leave for vacation and hit it twice as hard with dichlor, that way when you get back it's on, warm, and waiting for you.
bosco0633
  • Look into my eyes
« Reply #4 on: July 28, 2006, 01:24:32 am »
I agree do the change before you go and smoke it with chemicals so it is good when you come back.
Vanguard
« Reply #5 on: July 28, 2006, 02:00:35 am »
I also think you should drain and re-fill before you leave.  Your ozonator and silver (do you have that) should keep the spa clean and clear for you when you get back.  However, I don't think you need to overdo it with chemicals.  If you have a good CD ozone generator and silver cartridge, you'll be fine.
I would not drain and leave empty.  Spas want to have water in them.
« Last Edit: July 28, 2006, 02:02:03 am by aquatub »
Vanguard
« Reply #6 on: July 28, 2006, 02:02:47 am »
I also think you should drain and re-fill before you leave.  Your ozonator and silver (do you have that) should keep the spa clean and clear for you when you get back.  However, I don't think you need to overdo it with chemicals.  If you have a good CD ozone generator and silver cartridge, you'll be fine.  Of course, I'm assuming you'll have normal filtration and circulation going while you are gone.
« Reply #7 on: July 28, 2006, 04:43:11 am »
Should I:
I opt for B also. Leaving it dry is never good even though a week probably wouldn't matter. But why change anything. Just make sure it stays sanitized while you are away and drain when you get back. Or do it before you leave if you have time.
PotomacG
  • What's so funny 'bout peace, love & understanding?
« Reply #8 on: July 28, 2006, 10:02:10 am »
I am also going away for a week in August and plan on doing "B".
I plan on messing with the tub after vacationing.
