Author Topic: Jacuzzi J-350 24 Hr Pump - Help.  (Read 1695 times)
pratzert
« on: July 22, 2006, 05:18:00 pm »
Hi !
I have a Jacuzzi Premium J-350 and I "think" that I have a problem with the 24 hour circu;ating pump.
I assume that since it's called a 24 hour pump it should run 24 hours or very close to it.
for the last week or so, I have not been to check on the tub and witnessed the pump running.  Usually I see the little ozone indicator too but it's not showing on the display either.
I was checking things out again and I checked the return water into the tub and there "IS" water flow so some sort of pump is working.
I cranked up the temp to 104 and then the Ozononator symbol appeared on the display.
But there are no bubble coming from the return, so I am going to check the check valve to see if it's clocked up.
I wonder if this has something to do with the summer logic program.  I thought that unless the big pumps were on that the Ozone was on along with the 24 hour pump ?
Tim
« Last Edit: July 22, 2006, 05:32:39 pm by pratzert »
