Author Topic: Swirl Away Foam City  (Read 2725 times)
BearBath
  • Ya snooze Ya Lose
« on: July 12, 2006, 07:30:19 am »
I'm going through the procedure Vinny reccomended for refilling a tub that has been unused/drained for months. I filled it, put a cup of dichlor in, let it run for 2 hours and let it sit for 12 hours.
I'm getting ready to drain it again, and got a bottle of Swirl Away. It said to take the filter cartridges out... and I did. It said add 250 ml and run pump for 1 hour with no air. I added the swirl away and started up the pumps with the air controls turned off and got just a huge amount of foam. If I let this run for 1 hour, I will have foam trying to take over the backyard. What did I do wrong?
BearBath
« Last Edit: July 12, 2006, 07:31:54 am by BearBath »
rick_in_cleveland
Re: Swirl Away Foam City
« Reply #1 on: July 12, 2006, 07:57:35 am »
You did nothing wrong.  The foam is normal with swirl away.  If you really want to see foam turn on your air....WOW!.  Don't forget to cycle all of the diverters so the swirl away gets to all the pipes
« Reply #2 on: July 12, 2006, 08:13:24 am »
Yup- the times I've used the stuff I got a nice column of foam, maybe 2' tall.
« Reply #3 on: July 12, 2006, 09:03:36 am »
I should have taken a picture of my 6' wall of foam.  I turned the air off, but left the waterfalls and neck jets on high, and that really foamed.
« Reply #4 on: July 12, 2006, 12:01:36 pm »
BearBath
My tub didn't foam the way others have said that theirs had. I used 1/2 a bottle and ran the pumps for a total of an hour.
At least the tub is clean!
