Author Topic: Water temp?  (Read 2436 times)
blakley33
  • skin to win...in my tub!
Water temp?
« on: June 15, 2006, 05:10:58 pm »
I am just curious if this is common.
I was in my tub a few days ago and the water temp was at 96 and when I got out I lowered the setting to 92 so that the water would cool down a bit.
I live in the Kansas city area and it has been pretty warm here in the mid 80's to low 90's. Today I opened my cover and the temp read 99 degrees. would the water be able to raise 3 degrees with using no heat.
Just wondering if my heater is kicking on when it should not be.
If the heater is set lower than the water temp is reading it should not kick on until the water goes below the temp setting, is that correct?
Water temp?
Gary
Re: Water temp?
« Reply #1 on: June 15, 2006, 05:43:16 pm »
There are two heat sources in a spa:
1. Heater
2. Pump
During the hotter months the running a pump will raise the temperature of a spa. If you have the option of lowering the filter cycles this will help.
hottub.pool_boy
Re: Water temp?
« Reply #2 on: June 15, 2006, 11:08:29 pm »
Ditto to the gary man
Brookenstein
Re: Water temp?
« Reply #3 on: June 15, 2006, 11:14:11 pm »
You could also prop the cover open (tennis balls work well) and that will help keep the temp down.
rick_in_cleveland
Re: Water temp?
« Reply #4 on: June 16, 2006, 08:05:24 am »
Go to your local Kwik-E-Mart and get a bag of ice from Apu, throw it it and you will be fine
Re: Water temp?
« Reply #5 on: June 16, 2006, 09:59:35 am »
Is Bachelors III still open in Kansas City? ;D
I know how hot it can get in KC in the summer, but aren't the nights still reasonable? In the few 90 degree days we have had recently, it it still cool at night, so i just go out 30 minutes before we want to soak and open half the cover. But I still keep the tub at 101-102 in the summer, so it only has to drop 2-3 degrees.
blakley33
Re: Water temp?
« Reply #6 on: June 16, 2006, 10:17:15 am »
My wife and I were in the tub last night for about 30 min and I had the cover all the way open for about an hour before we got in and the temp droped 1 degree.
I can see the pumps running causing the temp to stay the same or even raise a little.
Maybe I should not be complaining, maybe it just means that I have an efficiant tub that does not loose heat easily.
I have not heard of Bachelors III here in KC
I have lived here for about 7yrs.
Thanks for the info guys.
windsurfdog
Re: Water temp?
« Reply #7 on: June 16, 2006, 10:32:23 am »
1. Heater
2. Pump
Actually, there are 3 heat sources:
3. Sun/ambient temperature
My spa is exposed to the sun constantly during daylight hours here in FL and it has a big influence on spa temp especially in the summer.
Re: Water temp?
« Reply #8 on: June 16, 2006, 02:19:22 pm »
It used to be the midwest's best "gentlemen's" club.  The guys at the GM plant use to take me there.
Re: Water temp?
