Author Topic: We got it!  & no floating!  (Read 3291 times)
In Canada eh
« on: May 22, 2006, 01:40:07 pm »
Our hot tub arrived last Sunday (Mother's Day)  -- been in it nearly every night since!  Now I can relate to all the hype.  I feel great.
I think I've discovered another cause of the "floating" syndrome.  Aside from needing sculpted seats, you need to "relax" (like only an experienced hot-tubber can do)  The first 2 times in our hot tub, I was disappointed to find I was floating a bit (didn't so much when I wet-tested?).  But on the 3rd time in, and every time since -- no floating!  So I think I was wound up in a tense ball, and was be pushed around by the jets -- but once I trusted the water depth and laid back and relaxed, no more floating!
So far, we love our tub.
Bullfrog 451
TN__HOT_TUB
Re: We got it!  & no floating!
« Reply #1 on: May 22, 2006, 01:42:05 pm »
Sounds good.
By the way, what hot tub did you get?
In Canada eh
« Reply #2 on: May 22, 2006, 02:22:24 pm »
Bullfrog 451.   Congrats on your 1st water change!  We too will likely be going thru the chemical-orientation trial & error program!
Bullfrog 451
salesdvl
« Reply #3 on: May 22, 2006, 02:40:03 pm »
Bullfrogs are known for the floating problem.  Just make sure the water depth from the seat to the surface is at least "Kneedeep"  "Kneedeep".   ;D   ;D
« Last Edit: May 22, 2006, 02:40:44 pm by salesdvl »
Measure once, cut twice.
« Reply #4 on: May 23, 2006, 02:32:04 am »
You thought of that yourself didn't you?
salesdvl
« Reply #5 on: May 23, 2006, 08:58:25 am »
I do write most of my own material.  ;)
« Reply #6 on: May 23, 2006, 10:20:08 am »
Welcome to spatopia eh! May you soak long and prosper, and my you only float when you want to.
8)
