Author Topic: first water change  (Read 3185 times)
TN__HOT_TUB
first water change
« on: May 21, 2006, 04:29:52 pm »
Well folks, I just completed my first water change.  I started draining it late last night before going to sleep (probably took 2 or 3 hours to drain).
My water was a bit cloudy and I thought I'd implement the 30 day newbie rule for changing water rather than continue to fight the cloudiness with chemicals.
Temperature in in the low 90s.  Looks like we'll be back in hot water this evening.
I gave the tub a good wipe down and also rinsed the filters (just cleaned them last week). I've added some of the metal-gone chemical and some dichlor.
Any pointers for a newbie?
first water change
Re: first water change
« Reply #1 on: May 21, 2006, 04:36:48 pm »
Chas would be proud.  Now that the first tub is past, my advise when you think you need to add something, put in 80% of what you did before.
Cola
  • Time for bed kids
« Reply #2 on: May 21, 2006, 04:40:37 pm »
Congrats on your first water change.  After the second, enjoy a good soak before chems.  The chlorine level out of the tap is likely measurable.
TN__HOT_TUB
« Reply #3 on: May 21, 2006, 04:53:08 pm »
I'm not exactly sure what caused my cloudy water problems, but the theory of "adding more chemicals" didn't seem to help.
I'd say the Water Brightener chemical (helps clump gunk so that it collects in the filters) Foam Gone or SpaPerfect probably contributed.  I'm very much wanting to add nothing but dichlor to this tub of water and forget all that other stuff.
« Reply #4 on: May 21, 2006, 04:56:05 pm »
As long as you mind the pH and TA.
sandiego
  • Caldera Spa Dealer for 30 years
« Reply #5 on: May 21, 2006, 05:26:02 pm »
also don't forget to put your defender in tomorrow.
Foam down will definately make the spa water cloudy if you use a lot of it as will the bright and clear.
keep it simple. add your dicholor and defender weekly and monitor the PH and alkalinity
I always try to use the matra that "less is more"
use the least amount of products in your spa to keep it clean and sanitized
TN__HOT_TUB
« Reply #6 on: May 21, 2006, 07:31:23 pm »
defender?  what's that?
i'm using artesian brand chemicals (except spaperfect)
TN__HOT_TUB
« Reply #7 on: May 22, 2006, 01:47:27 pm »
I had a fresh water soak last night.  First soak in the second batch of water.   Wow!   What a difference.  The water was crystal clear and squeaky clean.
It was super easy and well worth it.
« Last Edit: May 22, 2006, 01:48:13 pm by TN__HOT_TUB »
