Author Topic: Driver to change water  (Read 2106 times)
mxw128
  • Newbie with an 05 Vanguard
« on: May 06, 2006, 11:13:09 am »
What should tell me that I need to change water, is it TDS level?  I don't really have any problems with chem levels, I'm able to keep PH and TA pretty steady.  My water is a bit soft out of the tap, so I had hardness increaser occasionally.   I think the recommendation is to change water approx. every 3-4 months, but what "measurable" is that based on?
Re: Driver to change water
« Reply #1 on: May 06, 2006, 11:30:54 am »
In my case it is based on TDS, hardness, foam, waterline, filters -how often they need to be cleaned and how dirty they are when they ARE cleaned - and the amount the tub gets used.
Add that all up, divide by two, carry the one, and I have recommended three or four months for everybody.
Since we don't have freezing conditions or snow around here, I tell people the more you change your water, the longer you'll live, the better you'll look, and the more money you'll make. Seems to convince 'em.
The_real_Clown_Shoes
« Reply #2 on: May 06, 2006, 01:10:41 pm »
Don't look a gift horse in the mouth.  If you can keep your water clear and don't have any issues with it, just leave the water in there.  Why fix what isn't broken?
I've got a co-worker who deals mostly with commercial accounts that hasn't drained his hot tub in over three years since he's gotten it.  No issues with the water chemistry, equipment or anything.
If you look at a salt-chlorine generation pool, you'll start to run upward of 3500 TDS toward the end of the summer, well past the recommended 2000 or 2500 recommended drain point.
Tatooed_Lady
« Reply #3 on: May 07, 2006, 07:45:36 am »
3 years? ick......but that's just ME, I guess....as it's been said before...refilling your tub is the cheapest thing you can do to improve the quality of the water if/when you ever have issues.....that being said, I think today's a soakin' day.
RIP C-Rod
