Author Topic: Different Kinds Of Spa Shock?  (Read 4559 times)
Monk
« on: May 04, 2006, 02:06:43 pm »
Since my marquis uses bromine, I was wondering if there is a different kind of shock that i should use. I have pool shock, is that the same stuff in general?
Monk
hymbaw
Re: Different Kinds Of Spa Shock?
« Reply #1 on: May 04, 2006, 02:48:49 pm »
What kind of "pool shock" do you have?
Monk
« Reply #2 on: May 04, 2006, 03:02:32 pm »
HTH chlorine. But since my spa uses bromine, do they have a bromine shock?
Bonibelle
  • '05 Marquis Epic
« Reply #3 on: May 04, 2006, 04:10:34 pm »
Monk, Aren't you getting a chemical package with your tub?  I have found that managing the tub is much different than your pool. I have stayed with the chemicals that my dealer gave me and after a longer than usual learning period, I now have my water looking great.
I use SpaGuard Enhanced Shock with my bromine frog system.
« Last Edit: May 04, 2006, 04:13:17 pm by Bonibelle »
« Reply #4 on: May 04, 2006, 05:12:00 pm »
You have to read the labels - some pool shock is calcium hypochlorite - DO NOT USE THIS.
If it's sodium dichlor ..... whatever, it's dichlor and you can use it in bromine. You can also use MPS
HotTubMan
  • My 2.1 cents, eh
« Reply #5 on: May 04, 2006, 06:17:21 pm »
Vinny is right.
HTH in my experience in cal-hypo....keep that outta da tub.
You can shock with MPS (and various other non-chlorine oxidizers that usually have potassium in the chemical description), dichlor, lithchlor, brominating concentrate (85% dichlor) and I believe Brilliance.
« Reply #6 on: May 04, 2006, 06:38:07 pm »
Vinny is right.
Brilliance is a brand name that has an MPS shock.
HotTubMan
  • My 2.1 cents, eh
« Reply #7 on: May 04, 2006, 06:51:49 pm »
I sit corrected. The only time I have seen the product in person was at the NSPI (or whatever they are calling it now in Canada) show in December.
DPS
  • The light was yellow, sir
« Reply #8 on: May 04, 2006, 10:50:00 pm »
With my Marquis with the inline frog system I shock once a week with MPS and add a little granular bromine or dichlor if the spa gets higher than normal bather load during the week.
Monk
« Reply #9 on: May 04, 2006, 11:42:14 pm »
Thanks to you all for the advice!
Monk
hymbaw
« Reply #10 on: May 05, 2006, 11:13:02 am »
Right on Bonnibelle! See below
http://www.aquamagazine.com/data/archive/AQ-905-47.pdf
The_real_Clown_Shoes
« Reply #11 on: May 05, 2006, 02:41:39 pm »
Probably been said before, but with bromine you can use either dichlor or MPS as catalysts for shocking.
Bioguard Enhanced Shock is probably our most popular shock w/ bromine customers.
