Author Topic: Swim Spa Water Treatment  (Read 2433 times)
Reno-Swim Spa
« on: April 30, 2006, 09:41:59 am »
I need a little advice. I have a D-1 AFS unit aka a "swim spa". The unit hold approx. 1700 gallons and  keep the temp at 95 degrees, but I plan on lowering it to 80 degress for the summer. I've had the unit for 6 months and i'm still not sure how I should treat the water. My dealer is not very helpful. My problem is that all of the advise I've seen is for hot tubs that are at 100-1004 degrees. How should I treat mine? As a hot tub or a pool? Thanks
Ronald5599
  • HS Envoy installed May 5th - Very frustrated
Re: Swim Spa Water Treatment
« Reply #1 on: April 30, 2006, 10:45:16 am »
Can you put a picture on the forum?
« Reply #2 on: April 30, 2006, 11:16:53 am »
hottub.pool_boy
« Reply #3 on: April 30, 2006, 01:13:20 pm »
We've got several clients with them and prefer bromine tabs in a floater. It's convenient, add some ph + weekly, and they do use an UV ozone.
Seems to work well.
TN__HOT_TUB
« Reply #4 on: April 30, 2006, 03:38:17 pm »
I've always been curious about these swim spas.
Does the entire tub the temperature, or does it have two thermostats (swim side & spa side)?
Which side do you use most often?
Reno-Swim Spa
« Reply #5 on: April 30, 2006, 06:41:34 pm »
Our unit is the 16 foot version and the heat is only one zone. D-1 has a unit that is dual temp.
My dealer was against using bromine, says it's to corrosive.
