Author Topic: heating water  (Read 1848 times)
thearm
  • EMERALD CLASSIC all the way!!!
heating water
« on: April 28, 2006, 10:07:15 pm »
I refilled my tub last night and it took 13 hours to get up to 100deg. on the first and second refills it took around 9 hours. Water temp and air temps were comparable both times. Is this something I should worry about. Tub is just over 6 months old. Thanks for the help.
heating water
Re: heating water
« Reply #1 on: April 28, 2006, 10:09:48 pm »
Brand and model?
220 volt or 110?
thearm
Re: heating water
« Reply #2 on: April 29, 2006, 02:58:35 pm »
Chas,
emerald 699 classic 220 volt.
Re: heating water
« Reply #3 on: April 29, 2006, 03:17:14 pm »
That spa uses a Gecko/Spa Builders pack. It has a simple flo-though heater with a single element. That means that it is either on or not on, so the problem must be somewhere else.
Things to check: Take your filter out and soak it in a filter cleaning solution.
Be sure you are not opening the cover to check the temp - each time you do so adds close to an hour to the heating time.
Watch for flo indications: the dreaded 'three dot' signal which means that there is not enough water going through the thing: or the pressure switch is having trouble.
The Emerald web site has an excellant troubleshooting guide - it is the Gecko service manual in pdf format. Nice resource.
Re: heating water
