Author Topic: Fun with Dealer locators  (Read 4825 times)
« on: April 25, 2006, 01:49:17 pm »
I'm not in the market for a new spa.  I'm happy with what I have, but I thought I'd pretend and plan for shopping someday.
I also wanted a chance to do a review of the major sites's  dealer locaters as I would think they would be a major source of customers for my local dealers. Here is what I found.
I chose and looked up the sites of every spa I could think of, heard of, or knew someone who had one. (Sorry for any ommissions)
Alphabetical order (or at least I tried)
Arctic - Sorry no store within 40 miles of you . New Map feature that I  couldn't get  to work.  I don't think that is good marketing. I've writen them about it and they answered right back,  nearest dealer is more than 100 miles away.
Artesian - Same dealer as Cal/HS.  They report it as 10 miles away ƒº Its really 19  ;D - From the closest point in my zipcode it could be as close as 15.
Beachcomber - gives address Mapquest says it is 40 miles
Bullfrog - gives address Mapquest says 58
Caldera gives address Mapquest says 40 miles
Cal Spas same dealer as HS  Cal says 12 miles, it is 19 miles.From the closest point in my zipcode it could be as close as 15.
Coleman - Aprox. 90.47 miles ;)
Dynasty- 71 miles away  :'(
D1 -  Gives address  Mapquest says 50 miles
Hot Springs -  Gives address Mapquest says 19 miles
Hydropool lets you pick spas or swim spas - Spas dealer 15 miles - Didn't know it was there,  Looks like a pool store I  haven't been there. Requires info to get swimspa dealers. - I hate having to give up info. I happen to know the Hydropool swim spas are carried by the local Master dealer. (See Master  ;))
LA Spas - 4 miles - coming soon
Marquis - Gives address - Mapquest says 84 miles
Master Spas - I know the nearest dealer is about 5 miles away, but their site requires me to give up personal info - Forget it.  >:(
Sundance / Jacuzzi - 19 miles accurate
Vita spa 10 miles, didn't even know it was/is there. Locater lets you select how far away to look. I thought that was a nice touch. Will have to stop in sometime.
« Last Edit: April 25, 2006, 02:19:38 pm by wmccall »
Re: Fun with Dealer locators
« Reply #1 on: April 25, 2006, 01:54:24 pm »
Do you dealers check your mothership's site to make sure your info is accurate?
« Reply #2 on: April 25, 2006, 02:17:32 pm »
I saw that too. Catalina does it similarly but they direct you to regional reps on their site. I find it a turn off and I know as a consumer I'd probably skip them since the others give me direct info but that's just IMO.
« Reply #3 on: April 25, 2006, 02:22:49 pm »
I just checked Catalina, I think I have seen their spas at the Ohio State fair.  As close as I could get to dealer info is what I assume is the email address of a rep who covers
Eastern Illinois
Indiana
Eastern Michigan
Ohio
Pennsylvania
Virginia
West Virginia
« Last Edit: April 25, 2006, 02:23:08 pm by wmccall »
« Reply #4 on: April 25, 2006, 05:58:15 pm »
So give somebody else's info...
I'm sure they have telephones in Colorado, don't they?
« Reply #5 on: April 25, 2006, 06:08:15 pm »
But if I'm not mistaken, they have the dealer contact you.  Maybe I'm wrong, I'll try it.
« Reply #6 on: April 25, 2006, 06:37:21 pm »
D1 used to make you fill out the form and have the dealer contact you too.
In the past, I have found that some dealer locators are a little incaccurate.
Astually when I put in my zip, my dealer doesn't come up as my dealer any more ...
« Reply #7 on: April 25, 2006, 06:59:14 pm »
I do, but not as often as I should.  sometimes I find people being sent to my neighbors. :(
Gomboman
  • My Pride and Joy
« Reply #8 on: April 25, 2006, 09:33:01 pm »
Wow, it's not like yo live out in the sticks. I can't believe how far everything is from you?  ???
salesdvl
« Reply #9 on: April 25, 2006, 09:46:47 pm »
Hey, I just checked.  Hot Spring has a dealership in Anchorage, Alaska ( but not Nome which is what I searched for)
This concludes my random act for today.  ;)
Measure once, cut twice.
anne
« Reply #10 on: April 25, 2006, 10:30:23 pm »
That is quite a little piece of research-
when I was shopping, I looked up about 10 brands I heard of here- Sundance being one of them. None listed within a reasonable distance from me, so they were off my list even though they seemed like a brand I'd like to see. Then low and behold, a couple of weeks into shopping, reeling with all of the brands that I had seen, and making what I SWORE would be my last trip to Roseville (about 50-60 min. away with traffic), I saw a Sundance store- about 5 min after closing, all the lights off.
I did not go back, so I never got to check them out. Poor website- one potential lost customer.
These days, if you are not locatable online, you dont exist for a lot of people.
Dance like nobody's watching
Tom
« Reply #11 on: April 28, 2006, 12:50:55 pm »
Interesting; we have three dealers in OH (Hudson, Mayfield Heights, Dayton). Did you search using your zip code?  By selecting United States then Ohio in the drop-down fields, the map shows all three dealers and appears to work fine. Mapquest says Akron is about 75 mi. from Columbus, where you are.
I also checked some random US zip codes and CA postal codes and encountered no problems. We could easily expand the search to within 100 miles if you (and others reading this) suggest it.
Please send me a PM about your search parameters and difficulties with the map and I'll have our IT dept. look into any problems.
Tom
« Last Edit: April 28, 2006, 12:52:47 pm by Graybeard »
« Reply #12 on: April 28, 2006, 01:56:14 pm »
Just checked it again and using the zip 43229, it does say nothing is within 40 miles.  The Dayton store you mentioned is probably 80-90 miles away.
Tom
I' will check it again and PM you.   There is no way that Akron is 75 miles away from anything in Columbus. I live in NE Columbus and the easiest way to get to Akron is go North on I-71 from the 118 mile mark (Far north end) until I-76, which is the 209 mile mark, and then its at least 30 miles east.   Mapquest shows downton Columbus to Akron as 125 miles, so about 117 for me. When I emailed Arctic, they mentioned the Mayfield store. I think that was a year ago.
I did just retry the map and it worked this time in giving me the Dayton store which is 87 miles away.  I do think 40 miles is too small of a range for the text dealer locator.
The next time I'm Curling in Mayfield, I'll see if I can stop in for a look-see
« Last Edit: April 28, 2006, 01:58:55 pm by wmccall »
