Author Topic: water treatments  (Read 2529 times)
anne
water treatments
« on: April 17, 2006, 09:24:43 pm »
1) Any opinions out there about Leisure Time Bright and Clear vs Sea Klear CLarifier?
2) Is there a difference between Leisure Time Renew and Oz? The only difference I could find is that Renew advertises to be buffered/stabilized, and OZ says nothing about that, just says "ideal for ozone"- why? They seem to be about the same price, just granular versus tablet.
3) Is buffered/stabilized MPS worth the extra cost? I'm comparing Leisure Time Renew (32%MPS at $19.95 for 2lbs)  to Sea Klear Shock (45%MPS at $15.95 for 2.2 lbs)
thanks!
Dance like nobody's watching
water treatments
Re: water treatments
« Reply #1 on: April 17, 2006, 10:25:27 pm »
1. IMO both work well, but I don't use clarifiers much...only when I absolutely need to.
2.  LT Renew and Oz are the same...except Oz come in tablet form.
3. IMO non buffered MPS is the better product..you use much less.
« Last Edit: April 17, 2006, 10:25:56 pm by tony »
anne
« Reply #2 on: April 18, 2006, 10:20:51 am »
So the 32% and 45% dont mean that you'd need more of the 32%?
salesdvl
« Reply #3 on: April 18, 2006, 10:28:07 am »
My submersible pump that I use to drain my spa leaked oil, and when I refilled it I had a horrible mess.  I put a super dose of Sea Klear in and the next morning it was perfect.   I'm a big fan.
Measure once, cut twice.
« Reply #4 on: April 18, 2006, 06:04:00 pm »
You're not supposed to use the same pump for spa draining and oil siphoning! ;) ;D
« Last Edit: April 19, 2006, 07:54:52 am by Vinny »
« Reply #5 on: April 18, 2006, 11:20:22 pm »
Renew is buffered meaning there is an agent added to bring the pH to neutral.  You will need more of this product than a non buffered MPS.  Using a non buffered MPS will draw your pH down, so you would have to adjust on your own.  IMO you use a lot less product with non buffered MPS.  On top of that buffered MPS is expensive.  I use a very inexpensive non buffered MPS and of course baking soda to raise pH when needed is cheap.
anne
« Reply #6 on: April 19, 2006, 11:36:33 am »
thanks, Tony. I misread you the first time and thought you said "buffered MPS is the better product..." thus my question about the relative precentages.
