Author Topic: Cover Caddy mounting  (Read 3718 times)
KarlXII
  • Me before the spa
« on: April 15, 2006, 03:27:41 pm »
Today I got my Cover Caddy.  :D
I read the instructions, said "Be sure to screw into the frame of the tub".
OK.
So I took the cabinet side off. Of course there was no framework were the Cover caddy was supposed to be.
So I made some. I measured the distance between the frameposts, cut out some foam and put two boards there to screw into.
Worst part was actually to fit the cabinet side back on.
So, now I've got a Cover Caddy. :) It works beautifully.
Re: Cover Caddy mounting
« Reply #1 on: April 15, 2006, 05:11:07 pm »
GREAT pictures........... Any of the cover being removed?
KarlXII
  • Me before the spa
« Reply #2 on: April 15, 2006, 06:49:22 pm »
I'll post some here tomorrow. ;)
« Reply #3 on: April 15, 2006, 07:06:27 pm »
See, I wouldn't have even thought of that. I would have added some boards to the outside of the spa - going from support to support and then mounting the caddy on top of those. They would have had to be stained to match, and then maintained!
Your method is much nicer-looking, and you haven't exposed any more wood to the weather.
Good job.
KarlXII
  • Me before the spa
« Reply #4 on: April 15, 2006, 07:25:59 pm »
Good job.
Right, your method is what they suggest in the manual.
2x2 on the outside.
That looks terrible. I just couldn't make myself do it.
BTW, if someone else tries this, be sure not to cut too carelessly - there can be wires, hoses and plumbing inside the foam. I had to modify the upper board because of a drain hose.
KarlXII
  • Me before the spa
« Reply #5 on: April 16, 2006, 09:53:26 am »
Here you go. They pretty much speak for themselves.
I think it works beautifully.
The cover even leans away from the tub when opened. Nice.
Tatooed_Lady
« Reply #6 on: April 16, 2006, 09:58:10 am »
Very nice......I enjoy seeing what other lifters than the one I've got do.....
RIP C-Rod
« Reply #7 on: April 16, 2006, 10:19:59 am »
I agree.  I never knew that is how the cover caddy worked.  I always thought it stayed horizontal.  It even stows very low...and no stress on the hinge.
« Last Edit: April 16, 2006, 10:21:21 am by tony »
KarlXII
  • Me before the spa
« Reply #8 on: April 16, 2006, 03:47:54 pm »
Right. No stress on the hinge, and very easy to cover again.
There´s a gas spring that helps lifting the cover back up again You just have to push it a little on the top, and it swings up. Great.
