Author Topic: Too Much Water  (Read 8976 times)
paul
  • New Optima Owner
Too Much Water
« on: April 11, 2006, 01:57:01 am »
Help!
My Optima's water level was too low so I added water.  However, I was not paying close attention and overfilled the tub.  The water level is now about 1-2 inches above the bottom of the headrests.  Do I need to drain it some?  Am I in danger of harming the tub if I don't?  If I drain it just a little to get the level right, do I need to follow the owner's manual instruction to turn off the power at the breaker?
Too Much Water
tonyp
  • Soaking in a HS Envoy!
Re: Too Much Water
« Reply #1 on: April 11, 2006, 07:09:36 am »
Why play with the drain.  If you want to lower the water level a bit just bail it out with a bucket.
Re: Too Much Water
« Reply #2 on: April 11, 2006, 07:56:40 am »
Help!
I would bail a little out until just below the bottom of the headrests.  Yes, use a bucket or a syphon.  You do not have to turn the power off as long as you now pay attention and don't take too much out. ;D
« Last Edit: April 11, 2006, 07:57:48 am by tony »
J._McD
Re: Too Much Water
« Reply #3 on: April 11, 2006, 08:54:44 am »
Be sure to turn your air blower on to purge any water that got over the loop.  It is possible to get water back to the blower this way and that will trip the breaker.  Turning th blower on will push air through the lines and clear them in necessary.
Re: Too Much Water
« Reply #4 on: April 11, 2006, 09:14:28 am »
YOu could just put a hose up to one of the jets and turn them on.   In a few seconds you'll be ok.
I would keep the water line just below the headrests.
:D
Tatooed_Lady
Re: Too Much Water
« Reply #5 on: April 11, 2006, 07:58:40 pm »
I was going to say that this might be a great time to putz around and test out any syphon system you might plan to use at drain/fill time.... ;)
RIP C-Rod
r100rs
Re: Too Much Water
« Reply #6 on: April 11, 2006, 10:56:49 pm »
Or just invite a bunch of 5 years olds over.  Of course they could have it emptied faster than you want.
I believe WMCCALL has experience in this area.
r100rs
paul
  • New Optima Owner
Re: Too Much Water
« Reply #7 on: April 12, 2006, 10:46:24 am »
thanks everyone.  I don't know what i'd do without you guys.
Tatooed_Lady
Re: Too Much Water
« Reply #8 on: April 12, 2006, 10:52:19 am »
waste away with green foamy water and ring around the tub?  ;D ;)
RIP C-Rod
Re: Too Much Water
