Author Topic: cleaning used tub  (Read 3452 times)
dtaygtay
cleaning used tub
« on: April 08, 2006, 02:39:08 pm »
Just purchased a used hot tub.  What should i use to clean & disinfect the inside of my hot tub.   ???
cleaning used tub
Re: cleaning used tub
« Reply #1 on: April 08, 2006, 04:05:02 pm »
Cleaning is one thing - disinfecting is another.
Clean with soapy water - a couple drops of dish soap in hot water will take care of dirt and grease - the two biggies.
A fresh filter is the best way to handle THAT collector of flaked skin and subtances oozed.
And the disinfecting part is simple: after you have cleaned, rinsed (couple of times) stuck in the nice new filter and started your new tub, add a couple dry ounces of Dichlor (chlorine) to the water and check the chlorine level five or more hours later. Still have a readable chlorine level?
Jump on in, the water's fine.
hymbaw
« Reply #2 on: April 08, 2006, 04:19:30 pm »
What he said plus I'd use some Swirl Away or Spa Purge to clear any deposits of the previous owners biological debris out of the plumbing.
