Author Topic: High PH  (Read 2958 times)
Bosmani
  • lifes to short to drink cheap wine
High PH
« on: March 28, 2006, 02:08:09 pm »
Can't keep PH down..TA ok bromine levels ok...Views please..........
High PH
luvin_tubin_sqezin
  • Kiss my cartoon butt!
Re: High PH
« Reply #1 on: March 28, 2006, 02:16:46 pm »
Did those suggestions given in response to your last post not work?  (see bottom of this page)
Just curious.
Better than I deserve...
hymbaw
Re: High PH
« Reply #2 on: March 28, 2006, 02:28:47 pm »
How high is your ph?
Ph will tend to rise in a balanced tub (due to heat and aeration) If your ph slowly rises, that is normal, adjust as needed.
Bosmani
Re: High PH
« Reply #3 on: March 28, 2006, 06:12:06 pm »
hymbaw...........It right up there 8.2  I use ph down and then its up again  but then maybe its as you say just the norm....Thanks.........
Tatooed_Lady
Re: High PH
« Reply #4 on: March 28, 2006, 06:23:30 pm »
how does that pH perfect stuff work? Is it an option in your case?
RIP C-Rod
Bosmani
Re: High PH
« Reply #5 on: March 28, 2006, 07:03:41 pm »
Never tried it  but will look out for it   Thanks
Re: High PH
« Reply #6 on: March 28, 2006, 08:25:30 pm »
I bought some of that once.  For a 425 gallon tub I had to had 3 POUNDS of it.  Thats 3 pounds of solids dissolved into your water.   I'd rather keep playing with the PH and adding ounces of stuff here and there.
hottub.pool_boy
Re: High PH
« Reply #7 on: March 28, 2006, 08:36:49 pm »
Be careful with products that lock in pH. Most of them kick the calcium from the water, replacing it with a polymer. Where does the calcium go? Some gets trapped in your filter, to be rinsed out. The rest sticks to your heating element. Have seen some nicely coated. The bottle's directions fail to tell you to leave your heater off for 24 hrs. while the calium falls out of solution. Warranty departments do'nt like to see calcified heaters.
Tatooed_Lady
Re: High PH
« Reply #8 on: March 28, 2006, 08:39:55 pm »
oh, GEEZ  :o.....there's info I didn't know....but this is why I asked if it's an option (guess not so much)   :(
RIP C-Rod
Bosmani
Re: High PH
« Reply #9 on: March 29, 2006, 02:58:01 am »
Cheers guys,,,I stick with the test and adjust method.
galen
  • Maxxus
Re: High PH
« Reply #10 on: March 29, 2006, 03:43:46 am »
Mine had been high for a while. I added muric acid a tablespoon at a time till it was down to normal. The PH is stable now. I'm on Dichlor. But every third day I use activate. This seems to keep foaming down.
« Last Edit: March 29, 2006, 09:45:59 am by galen »
Re: High PH
