Author Topic: Hotspring Temperature display panel question  (Read 2916 times)
Gomboman
  • My Pride and Joy
« on: March 05, 2006, 11:53:38 am »
I would like to read the actual water temperature from my HS Envoy. Has anyone rigged up a separate temperature controller that reads actual temperature real time?  Better yet, I wish there was a "Hop Up Kit" that would work with the IQ 2020.
Am I the only geek who would like to do this?  ???
Re: Hotspring Temperature display panel question
« Reply #1 on: March 05, 2006, 01:04:34 pm »
Radio Shack used to have a cool little thermometer which had indoor/outdoor temp readings. The outdoor temp was taken from a little probe which was on the end of a length of small wire.
I just checked, and they seem to have gone to a wireless model for a bit more money: $39.97 for a Model: 63-1089
Catalog #: 63-1089
That would be the easiest way to get a realtime readout of the spa temp.
As to modifying the panel, I don't know of a way to make it read the current water temp, but if the green light is on, it is usually within a degree of the set temp.
« Reply #2 on: March 05, 2006, 01:08:06 pm »
The IQ2020 does have the capability of reading temp.  They just don't tell us how.
Markus
  • HS Vanguard 2005
« Reply #3 on: March 05, 2006, 06:45:38 pm »
I have a factory calibrated digital thermal probe and tested the accuracy of my Hotsprings tub. I found that the temperature was approximately 2 degrees hotter than it was set for. This was a consistant reading taken over a few days.
I then took 2 different pool thermometers and tried them also...they too, read about 2 degrees higher than the tubs' setting.
Not a big deal to me...but it just tells me that the tub isn't that accurate.
