Author Topic: Spa Start Up  (Read 2452 times)
paul
  • New Optima Owner
Spa Start Up
« on: February 02, 2006, 02:39:23 am »
I just received and powered on my new Sundance Optima today.  For someone who has trouble changing a light bulb, start up seemed real easy.  We just filled the tub with water, followed all instructions re: chemical start up, changed the filter after filling the tub, and turned up the heat.  No problems so far, but it seems to easy.  Am I missing something or in for a nasty surprise?
Spa Start Up
Re: Spa Start Up
« Reply #1 on: February 02, 2006, 08:16:25 am »
Sounds to me like you got it.  Test the water every so often, and enjoy the spa.
ggwagner
Re: Spa Start Up
« Reply #2 on: February 03, 2006, 01:52:11 pm »
Hey there Paul,
You're all good.
The tub will do most things automatically. You could set your time for your region and set your temp - easy to do and explained in your owners manual.
Keep testing the water with strips and take in a water sample fo testing to get more accurate readings. Then you can make some minor ajustments to water if need be.
Enjoy.
Glenn Wagner
Sundance Spas Orillia Ontario
paul
  • New Optima Owner
Life changing Experience
« Reply #3 on: February 08, 2006, 03:08:31 am »
In the 7 days I have had my Optima, I have not gotten up in the middle of the night once b/c of back pain.  I feel like a new person.
« Last Edit: February 08, 2006, 03:10:04 am by paul »
Bonibelle
  • '05 Marquis Epic
Re: Spa Start Up
« Reply #4 on: February 09, 2006, 08:06:35 am »
I know just how you feel!   Doesn't the world look so much brighter after a good night's sleep?  ;)
paul
  • New Optima Owner
Re: Spa Start Up
« Reply #5 on: February 11, 2006, 05:34:13 pm »
everything in life is better now
Re: Spa Start Up
