Author Topic: Math problem  (Read 3336 times)
sunnydee
Math problem
« on: January 09, 2006, 02:21:23 pm »
I just received my Sea-Klear clarifier. One ounce treats 5,000 gallons. Of course, my tub isn't 5,000 gal, but rather 300 gallons! Any mathematicians out there???
Math problem
tonyp
  • Soaking in a HS Envoy!
Re: Math problem
« Reply #1 on: January 09, 2006, 02:25:08 pm »
300/5000 = 3/50 = 0.06 oz.
Now what is that in drops?!
If you use an eyedropper - find out how many drops are in an oz. multiply that number by 3 and the divide it by 50.  That's your answer.
« Last Edit: January 09, 2006, 02:27:23 pm by tonyp »
East_TX_Spa
    • I Love My Spa
Re: Math problem
« Reply #2 on: January 09, 2006, 02:25:14 pm »
Spatech tuo and drewstar are good at numbers.  Ask their bookies!
Terminator
J._McD
Re: Math problem
« Reply #3 on: January 09, 2006, 02:48:58 pm »
Feel free to use 1 ounce for overkill and be done with it.  It was originally intended for use in pools as well.
sunnydee
Re: Math problem
« Reply #4 on: January 09, 2006, 02:58:23 pm »
Thanks. I just put a Tablespoon of the Sea Klear diluted in some water, then added to the tub. What's the worst that could happen?! The bottle says its safe for fishponds...lol. :-/
bulmer4nc
  • Now a Canes Fan.
Re: Math problem
« Reply #5 on: January 09, 2006, 03:11:51 pm »
It sounds like you got the 'pool' version.  I'm guessing there's a difference in how they're diluted or something.  I'll look at my bottle at home and let you know what it says for dosage.  I know the bottle I have says it's for Spas and Hot Tubs and the dosage is based on 500 gallons I think.   I typically put in 1 or 2 oz when I use it.
Ken
Gomboman
  • My Pride and Joy
Re: Math problem
« Reply #6 on: January 09, 2006, 09:25:34 pm »
Wow, this stuff goes a long way.  What are you using it for? Is this the best clarifier to use?
Re: Math problem
« Reply #7 on: January 09, 2006, 09:54:19 pm »
I just bought some from Doc and I could swear it said use 1 oz per 250 gallons on his website.
BTW the amount that tonyp stated would be less than a teaspoon, but then again maybe on a teaspoon  the measurement is dry weight not liquid.
« Last Edit: January 09, 2006, 09:55:09 pm by Vinny »
Kelly
  • Hot Springs Accolade!
Re: Math problem
« Reply #8 on: January 10, 2006, 08:36:02 am »
simple - just add one ounce of concentrate to a bottle, then add 16 ounces of water to that.
Then use one ounce of your dilute soultion in the tub.
bulmer4nc
  • Now a Canes Fan.
Re: Math problem
« Reply #9 on: January 10, 2006, 11:41:56 pm »
So...  My bottle of SeaKlear reads like this:
[size=48]SeaKlear[/size]
[size=18]Natural Clarifier[/size]
[size=16]For Spas and Hot Tubs
[/size]
Dosage
  • Standard Dosage: Use 1 fl. oz. of SeaKlear Natural Clarifier for each 500 gal. of spa or hot tub water.  No premixing required.  Do not dilute.
  • Cloudy Water Dosage: If your water is especially dirty or cloudy, you can double or triple the standard dosage without any side affects.
(ok... I was having a little fun with the size and color...)  :)
salesdvl
Re: Math problem
« Reply #10 on: January 11, 2006, 10:35:08 pm »
Sea Klear.  Great stuff.  A couple of years back I drained my spa with my submursible pump only to find that when I refilled it I had an oil slick from the leaky pump.  It was gross.  I called the Sea Klear Rep and he suggested putting the entire quart in (300 gal spa).  He also sad he had never had to fix this kind of prob before.  Anyway, next morning, poof, perfect water.  replaced the filter and back in business.
Measure once, cut twice.
Re: Math problem
