Original
Shock
Pages: [
Topic: Shock (Read 3350 times)
hamrhed
Full Member
"Hard Tellin" "Not Knowin"
Shock
on:
January 07, 2006, 09:34:18 am »
Can I shock with DiChlor in a Bromine Tub with no Ill effects,or should i use MPS???
Shock
on:
NJDave
Full Member
It's just more fun to be in hot water!
Re: Shock
Reply #1 on:
January 07, 2006, 10:23:18 am »
Shocking with the Dichlor, will not make you ill or ruin your tub, but if you are using Bromine, I would stick with the MPS Shock.
Dave.
HotTubMan
Senior Member
My 2.1 cents, eh
Re: Shock
Reply #2 on:
January 07, 2006, 11:17:22 am »
I have seen no ill effects from shocking a bromine spa with dichlor.
The only negative I see to using the MPS (pH around 2) and Bromine tablets (pH around 4) is that you are going to need more TA & pH + than you would using the tablets with dichlor (pH 6-7)
Ultimate Member
Re: Shock
Reply #3 on:
January 07, 2006, 04:38:54 pm »
I can vouch for that. Between Bromine and MPS I have to adjust my alk and Ph quite a bit.
Mentor Level Member
Re: Shock
Reply #4 on:
January 07, 2006, 08:46:46 pm »
If you want to shock with dichlor in a bromine spa you can go right ahead without hesitation. It's perfectly fine and if the water is a bit iffy I'd personally prefer that route over MPS.
hamrhed
Full Member
Re: Shock
Reply #5 on:
January 08, 2006, 10:32:31 pm »
What would you recomend for dosage?
My tub is 395 Gal. rated.... My guess would be 3Tbls?
Re: Shock
Reply #5 on:
Pages: [
Original
Shock
