Author Topic: Between Artesian and Hot Spring  (Read 4851 times)
Re: Between Artesian and Hot Spring
« Reply #15 on: January 02, 2006, 12:10:35 pm »
HS will replace the heater for any reason including improper water but water chemistry is fairly easy.
The PH is easy along with calcium and sanitizer once you get a handle on it and the heater elements don't self destruct on you with a little batch of "unbalanced" water.
Either tub will serve you well, but ultimately you need to feel 100% comfortable with your decision.
