Author Topic: foam/filter cleaner  (Read 2358 times)
r100rs
foam/filter cleaner
« on: December 22, 2005, 11:31:50 am »
The advice on given on this board is to rinse your filters a coupleof days after using any "foam away" products.  My question is do you just use water or some filter cleaner.  If a cleaner, which one and can it be used with Sundance's microban filter (the one that the manual states to not rinse - replace)?
r100rs
foam/filter cleaner
Re: foam/filter cleaner
« Reply #1 on: December 22, 2005, 11:40:28 am »
r100rs
It's my understanding that the term "rinse"means to wash/flush with clean water only"
"Clean the filter" or "Wash the filter" indicates to use a cleaning product.
At least that's how I use the terms.
johnvb
  • 2005 Optima! (indoors)
« Reply #2 on: December 22, 2005, 12:29:09 pm »
Just a warning...I've changed the water once in my Optima, and at that time thought I would just rinse out the disposable filter a little, since I am hoping to get at least 8 months out of it.
Well, it looked as if it started to come apart by the water pressure, so I stopped.
I would suggest you get one of the $60 washable filters that can take the place of the throwaway, just for the time period you want to flush out the foam away stuff.
I have one as a spare, just in case my dealer doesn't have the disposable filter in stock when I will need it, or if something major happens were I need to do multiple rinses.
hymbaw
« Reply #3 on: December 22, 2005, 02:53:50 pm »
You can't clean a SD Microclean filter, just replace. The filters are depth loading so the "dirt" can't be rinsed away like on a traditional paper filter(which are surface loading)
