Author Topic: Leaving J385 home alone  (Read 1918 times)
modman
« on: December 16, 2005, 02:18:55 pm »
Hi everyone,
I've been lurking on this board for a couple of months now and after reading all the fine advice and tips here finally bought and installed a new J385.  So far everything is great and the family loves it.
Now for my question.  We'll be away for about 10 days at X-mas without anyone to pour the needed chemicals into the tub.  Anyone have some advice as to what I should do?  My initial plan is to make sure the pH is good, add a bunch of shock and hope for the best.  Any other ideas?
Re: Leaving J385 home alone
« Reply #1 on: December 16, 2005, 02:22:14 pm »
IF the tub is clean and sanitized before you leave, and no one uses it, and it filters (either on a circ pump or a timer) you should be fine.
Might want to clean the filters too.
« Last Edit: December 16, 2005, 02:22:35 pm by drewstar »
Does your spa know that you're out?
« Reply #2 on: December 16, 2005, 02:46:18 pm »
I agree with the Drew.
If you use Dichlor, put in a shock before you go, and check it when you return.
For folks who are going to be away longer than ten days, lowering the water temp can help a lot: chlorine will stay is water that is 80 degrees much longer than it will stay in 102 degree water.
