Author Topic: Bro to Dichlor change  (Read 3833 times)
hamrhed
  • "Hard Tellin" "Not Knowin"
« on: December 05, 2005, 10:55:48 am »
Is it possible to change sanitizer from Bromine to Dichlor without changing the water?
If so should i wait for the residual level of Bro to drop off the scale or just start the change over?
Is the shock i use with the Bro, (SpaGuard -Spa Shock Potassium Peroxymonosulfate 31.0% Other 69%)compatible with Dichlor?
Just wanted to know. I won't be doing this until i use up what i have on hand.
Thanks,,, Chris
hymbaw
Re: Bro to Dichlor change
« Reply #1 on: December 05, 2005, 11:13:54 am »
You'll have a difficult time switching without draining. It's possible but not worth the hassle.
MPS is a fine oxidizer for either.
« Reply #2 on: December 05, 2005, 11:33:01 am »
I've heard you need to change water to switch from bromine to chlorine.
You can go from chlorine to bromine without a water change.
« Reply #3 on: December 05, 2005, 11:44:40 am »
The shock you have is fine for chlorine.
Realistically, a bromine sanitized spa can not be switched over to chlorine, if there's still bromine in the water. All the chlorine added to the water is going to convert bromide ions into hypobromous acid. As long as there's 15 ppm or more of bromide ions in the water, all the chlorine added is going towards converting bromide ions into hypobromous acid, none of it will provide a chlorine residual. The spa will continue to be bromine sanitized until the bromide level gets below 15 ppm. There is no test kit for measuring just bromide ions in the water and therefore no way to know when the bromide level is below 15 ppm. It could take a week. It could take 2 months.
hamrhed
« Reply #4 on: December 05, 2005, 12:44:32 pm »
Thanks for the Info
I'll just wait for the first water change to make a switch...
Ya learn somthin new every day...
Have a good one  :)
st18901
  • '86 Sovereign!
« Reply #5 on: December 05, 2005, 12:53:57 pm »
Out of curiousity, why do you want to switch?
hamrhed
« Reply #6 on: December 05, 2005, 01:03:05 pm »
Good question...
I don't know...  seem like i get a little itchy skin about half hour after a soak... not too bad at all.. just thought i would try the dichlor next time...
Still in the trial stage.. I guess
« Reply #7 on: December 05, 2005, 01:30:40 pm »
Good question...
I think you'll like the switch, most do.
hamrhed
« Reply #8 on: December 05, 2005, 03:28:25 pm »
Thanks Spatech,
So you think its a good call?
It seems like most people here use Dichlor...
st18901
  • '86 Sovereign!
« Reply #9 on: December 05, 2005, 03:54:18 pm »
I use Bromine and MPS for shock.
So far, I love it. I used chlorine in my last hot tub. I personally prefer bromine... I think.
« Reply #10 on: December 05, 2005, 04:07:08 pm »
I went from Baqua to Bromine.  So far I'm okay with Bromine, but wouldn't have a problem switching to dichlor if I needed to.
« Reply #11 on: December 05, 2005, 04:33:59 pm »
That's the kind of response I like. I don't care for Bromine at all but by trying both you can at least compare. In my travels, I've found that most people who've tried both prefer the dichlor but I certainly have met a few who are the opposite and if after comparing they prefer Bromine then that's great.
hamrhed
« Reply #12 on: December 05, 2005, 05:28:20 pm »
seems to be an even split,,,,  personal pref...
ill give it a shot next h2o change (spring) and see if i like it better, same or not at all...
thanks for the input fellas...
I'll be in tonight....  Spatopia you call it...  oh ya
