Author Topic: Whats your default?  (Read 3392 times)
Whats your default?
« on: December 03, 2005, 10:36:02 pm »
My tub provided a rare dissapointment today.  This time of year ours is kept at 104.  I over did it at the gym yesterday so I was looking for a good HOT therapy soak tonight.   It was 27 degrees here tonight so you can spend longer at 104 than you can in warmer weather. I didn't even think to look and I got in the tub and thought this doesn't feel right.  I looked at the display and it was flashing, meaning there had been a power failure.  My tub defaults to 95 degrees and 2 hours of filtration as a power up default.  That got me thinking why 95?  Our tub never goes below 98, so I have to wonder why they picked 95F.   What does your tub default to?   To add insult to injury, even though it was 27 degrees, it started to rain.  I will tell you that you don't have the same stay warm time after getting out of the tub at 99 that you do at 104.
Whats your default?
spaman--
Re: Whats your default?
« Reply #1 on: December 03, 2005, 10:46:25 pm »
Most tubs in the industry default at 100 degrees.
-SpaMan~
LtDan
  • Jacuzzi J345
« Reply #2 on: December 03, 2005, 11:01:57 pm »
I believe mine goes to 101. I also keep mine at 104 this time of year, just went out to get in and it is freezing rain. I don't mind snow, actually like tubbing in it, but have to pass on this stuff.
« Reply #3 on: December 04, 2005, 06:38:29 am »
Mine defaults to 100 and 2 hours filtration also after a power down. I like 102 this time of year. Last night it was 5 above with snowfall and it was perfect for a couple hours and a bunch of beers and BS with my little bro. Cept the hair (what little I have) on the back of my head gets crispy.
JcDenton
  • Be Cool or be cast out
« Reply #4 on: December 04, 2005, 09:43:19 am »
I believe we're 101 - definitely above 100 for sure -
Jc
tonyp
  • Soaking in a HS Envoy!
« Reply #5 on: December 04, 2005, 10:25:35 am »
I believe that my HS Envoy resets to whatever you had the temperature set to (102 for us) and 24 hr. filtration, of course.  One less thing to worry about in a power failure!
« Reply #6 on: December 04, 2005, 11:37:35 am »
Yea, it was a wierd night last night, the therometer said it was 27 outside, and once we got settled into our 99 degree tub is started raining.  Had a nice soak at 104 this morning though. I could sit in the tub and listen to all the cars sliding down the street this morning as everything has a nice coating of ice. Getting ready to venture out and see how bad it is.  Sunday is lunch at The House of Japan day.
Guzz
« Reply #7 on: December 04, 2005, 11:44:12 am »
You are correct Tony, all Hotspring spas will automatically go back to the last set temperature, Tiger river too.
Ruby
  • Marquis Epic
« Reply #8 on: December 04, 2005, 11:48:38 am »
The default on my 2004 SA Reward was 102.  The default on my new Epic appears to be the the last set temp.
Minnesota Consumer
Been soaking since 7/2004
HotTubMan
  • My 2.1 cents, eh
« Reply #9 on: December 04, 2005, 12:01:54 pm »
Hydropool and Coleman default to 100, 2*3 hour filter cycles. They both use Balboa M-7..
Beachcomber defaults to 100. 24 hour with hush pump, 2*6 hour without.
D-1 is 100 degrees, 24 circ plus another cycle with pump 1, which evades m y memory. I do rememmber you can have pump 1 run as many as 4 times a day for a period of time...
« Reply #10 on: December 04, 2005, 01:47:58 pm »
I'm pretty sure that my Optima goes back to the last set temperature.  The spa is powered off several times per year for water changes and stuff, but I never have to re=adjust the temperature.
« Reply #11 on: December 04, 2005, 02:58:29 pm »
Same with me.
NE-Phil
  • Marquis Reward '05
« Reply #12 on: December 04, 2005, 11:29:33 pm »
I just checked the manual. My '05 Marquis Reward defaults to 102F (39C for all of you way up North).
Phil
