Author Topic: getting cold  (Read 2879 times)
chaunceyboyblu
  • im daddy
getting cold
« on: December 01, 2005, 10:14:56 pm »
hey its getting really cold here. will these continue to maintain temp even when it gets way below zero? also what happens if it is say 40 below and the heater breaks?
getting cold
Re: getting cold
« Reply #1 on: December 02, 2005, 12:53:55 am »
If it's really, really cold, like below zero, your spa may loose a degree or two while you use it.  Depends on the spa.
Check your owners manual to see if there are any special instructions for sub zero temperatures- mine has some special instructions for when it hits -30F, If I recall.
If it's -40 and your heater quits, act quickly to prevent water freezing if at all possible, and hope you get the problem fixed before plumbing freeze sets in.
Your owners manual may also expain what to do here, or ask your dealer what they'd recommend for your spa.
Do you have 2 sets of steps on that spa?  I'm seeing your top step full of snow, but no footprints.  Or did you dive over the side or something?
« Last Edit: December 02, 2005, 12:55:22 am by Brewman »
ramdom
  • Hydropool 625er.
Re: getting cold
« Reply #2 on: December 02, 2005, 03:11:37 am »
I was thinking the same thing.
Re: getting cold
« Reply #3 on: December 02, 2005, 04:45:51 am »
If it's below 0 and your spa quits you have to get it fixed ASAP if it's not going to happen that day then you will have to figure out how to keep the equipment from freezing. There's several ways to do this including a light buld, small heater, forced air system. But which ever way, if no water is being moved or heated it will have to be drained. And your drain will have to be done so as to evacuate all water from the system including the pump. Make sure you talk to your dealer or local service guy regarding this if it is a concern.
chaunceyboyblu
  • im daddy
Re: getting cold
« Reply #4 on: December 02, 2005, 11:00:30 am »
ard to believe but we had been in maybee an hour and it snowed that much.
chaunceyboyblu
  • im daddy
Re: getting cold
« Reply #5 on: December 02, 2005, 11:22:54 am »
hey thats a great idea about a heater, seems like it would be wisw to put one down there and have it all wired up for when the heater does break, seems like it would break in the winter.
Re: getting cold
« Reply #6 on: December 02, 2005, 05:21:46 pm »
Cool!  I bet it was pretty fun, sitting out in the snow like that.
Re: getting cold
