Author Topic: Question on di-chlor  (Read 4460 times)
cappykat
« on: December 01, 2005, 11:53:12 am »
I'm sure this is in a post somewhere but I can never seem to find anything when I search.
I went to my local pool supply store this am and asked for di-chlor.  He gave me a product by Omni called Algae Destroyer.  It says, "sodium dichloro-s-triazinetrione dihydrate 99.0%".  Is this what I want?
2005 Marquis Epic
Re: Question on di-chlor
« Reply #1 on: December 01, 2005, 11:58:22 am »
Yes.
The packaging seems to be marketing as  a pool shock, so be careful with  the dosage it may say on the bottle.
Sodium dichloro-s-triazinetrione dihydrate 99.0%  is Dichlor and the same % of active ingreadients as my Spa 56 that I use from Leisure time.
« Last Edit: December 01, 2005, 12:00:42 pm by drewstar »
Anoroc
« Reply #2 on: December 01, 2005, 12:00:37 pm »
You got it Cappy!
cappykat
« Reply #3 on: December 01, 2005, 12:00:49 pm »
Thanks, Drew...and Anoroc!!
« Last Edit: December 01, 2005, 12:01:57 pm by cappykat »
2005 Marquis Epic
Soakin
« Reply #4 on: December 01, 2005, 12:00:55 pm »
Yes, but do you really want to put something called "Destroyer" in your new tub and soak in it :P?  It will do the job, but I'd look for another brand with a kinder gentler name. 8)
cappykat
« Reply #5 on: December 01, 2005, 12:03:33 pm »
I just spent $12.47 on this stuff...so yes, I'm using it.  Although you did make me stop and think for a minute...next time I'll find a "kinder, gentler name" to soothe you and me...LOL!! ;D
« Last Edit: December 01, 2005, 12:10:49 pm by cappykat »
2005 Marquis Epic
« Reply #6 on: December 01, 2005, 12:04:00 pm »
Is this what you got:
http://www.focuspools.com/products/Omni/Algaecides-ALGAE-DESTROYER.asp
If so, disregard the dosage. You're skin will fall off.  :o
But it's Dichlor. Just use "spa doses" as discussed here, don't dump 2 lbs in.
« Last Edit: December 01, 2005, 12:17:09 pm by wmccall »
cappykat
« Reply #7 on: December 01, 2005, 12:06:32 pm »
Yes, that's exactly what I got.  Are you saying not to use??  I can take it back.  What do you suggest?
2005 Marquis Epic
Soakin
« Reply #8 on: December 01, 2005, 12:11:51 pm »
No, I was just teasing.  It's fine to use -- just in tsp and Tbls, not pounds or cups. :o
« Last Edit: December 01, 2005, 12:18:32 pm by Soakin »
« Reply #9 on: December 01, 2005, 12:16:24 pm »
For how many pounds.  I'm finding $4-5 a good price and can get closer to $4 when buying a 5# bottle.
My local Hotsprings/Cal dealer sells this one for $24 for $5, which is hard to beat around here.
« Last Edit: December 01, 2005, 12:21:02 pm by wmccall »
cappykat
« Reply #10 on: December 01, 2005, 12:17:11 pm »
I got ya!!  Never again will I do anything in POUNDS when it comes to the hot-tub!! ;D ;)
It was $12.47 for a 2lb bottle.  I was going to put in 2 OUNCES...is that ok?
« Last Edit: December 01, 2005, 12:18:53 pm by cappykat »
2005 Marquis Epic
« Reply #11 on: December 01, 2005, 12:23:10 pm »
My thinking is 2 ounces is a good amount for a shock done every week or two.   I usually put in about a tablespoon or two when  I get out.   2 ounces isn't going to hurt anything, but just I'm betting you will notice a strong chlorine smell and your levels will be real high for quite a few hours.
« Last Edit: December 01, 2005, 12:23:39 pm by wmccall »
Soakin
« Reply #12 on: December 01, 2005, 12:25:33 pm »
I don't know what kind of sanitizer routine you are on, but the range for daily doses discussed on this forum seems to be 1/2 tsp to 1 Tbs per user per half/hour. (I use 1.5 tsp/user/30 min -- that gets my 525 gal tub up to 5 ppm), so 2 oz would be a lot for a daily dose, but about right for a shock treatment.
« Reply #13 on: December 01, 2005, 12:41:10 pm »
No keep it. It's exactly what you want. It's packaged as a pool shock, so the directions are going to be geared towards a 10,000 gallon pool. but it is EXACTLY the same as the fancy smancy overprices Spa bottleing. That's it.
Listen to folks like WMcall and Drpsa (except for magnets  : )  - sorry couldn't resist :)   - for dosages, as well as all  the other chem pros here....  and you'll be fine.   I am just a dilatante.
« Last Edit: December 01, 2005, 12:48:23 pm by drewstar »
Anoroc
« Reply #14 on: December 01, 2005, 12:55:48 pm »
Cappy, I don't know if you have a Sams nearby but I picked up a case of Dichlor that had 16 packages each of one pound for a total of $26. (for 16 lbs of dichlor).
My jetsetter is pretty small so I will have sanitizer to spare for a very long time.
