Author Topic: how to stop overheating and low Flow  (Read 6794 times)
water@104
  • Sitting here doing what i do best!
Re: how to stop overheating and low Flow
« Reply #15 on: October 04, 2005, 09:31:19 am »
Well i took out the filters and let the tub run for a while and i am still getting the Low flow. any other ideas?  ???
stuart
« Reply #16 on: October 04, 2005, 05:39:01 pm »
Well,
Not ever hearing of the "riptide" brand I have no idea whether they use a flow switch or pressure switch but with the info given I would have to guess your problem is with which ever you have.....
If it is a pressure switch you might be able to bypass it and test it.
water@104
« Reply #17 on: October 13, 2005, 04:40:56 pm »
Well,
thanks fo rall your ideas. Come to find out that i ended up having a bad low gear in circulation pump.
Since it was a bad low gear it was turning on but never circulated the water which inturn cause the LF which inturn caused the over heating or the cooling of the water.
So now i am waiting for the new pump to arrive so it can be changed out. I pray this fixes all my headaches
