If pump failure rates due to clogging are significantly different for HS than other manufacturers using pumps of equal, high quality, I would be glad to learn the details.
Somewhat correct, but I believe you may be misinterpreting the context of the statement. 100% No-Bypass Filtration means that 100% of the water is filtered BEFORE it enters the plumbing. It is not intended to infer that all five filters are "filtering" 24/7. When the jet pumps are off, water is continuously filtered through the circ pump filter. When the jet pumps are running, water passes through all 5 filters. It pains me somewhat that you and Wisoki seem to think I'm blowing smoke. I believe that I've represented myself on this board as straightforward as anyone possibly could. I don't hide anything about me or the company I work for. I consider myself to be a straight shooter.HotSpring IS the world's #1 selling brand of portable spa. There are reasons why they are. The longevity and quality of the product is a primary reason. If other spa companies are not giving their customers the same quality experience of spa ownership, that is to the customer's detriment, and is a shame.Terminator
I respectfully have to strongly disagree
Or, maybe, just disagree...So glad you "respectfully" disagree with someone by calling them a liar.I think you are wrong, and the whole mentality of your post speaks more to someone with a bone to pick with HS than someone just looking for information. Your not a passionate expert on HS, but you certainly seem passionate about it.respectfully,-Ed
My conclusion is that the benefits of the Tri-X filtration system are nebulous.
As it relates to motors, with 21 years and so many customers that would be .002% motor failure, and I would find that spectacular. But then again, these motors are single speed and run for maybe only 20-40 minutes a day, even if it is 365 days a year for 21 years.
East Tex Spa:I wrote: "If pump failure rates due to clogging are significantly different for HS than other manufacturers using pumps of equal, high quality, I would be glad to learn the details." You replied: "This, sir (with sincere respect), is the whole impetus behind having 100% No-Bypass Filtration."So you have made a claim, but you have only anecdotal information from your own experience, nothing on the failure rate from competition (keep in mind you would need to establish the pump failure rate for major brands) to back your argument. Not only can you not back your claim, but your argument is faulty.
I am glad that you think HS makes the best spas and the best filtration systems. I think you have blown the significance of the Tri-X filter design way out of proportion. It is a sales argument, not a user benefit of great value. It is nice that they last for a long time and that they can be thoroughly cleaned in an ordinary dishwasher. But they use up a lot of space and the water is not any cleaner in the tub. A mixed blessing.Thanks,Bill
I am truly sorry if I offend you.
With me being one of the unfortunate people there that does not currently have nor have I ever owned one I must admit the no bypass filtration really appeals to me. I like the idea that the filter will prevent the sucking up any small items that may find there way into the tub, after all I have a 2 year old sun and things are winding up in all areas. For some reason I do believe that if a service tech were to find a lego in the pump housing of a failed pump it would not be considered a warranty item. I have been following this thread and felt I had to add my opinion to those being expressed. I give it to Hotspring, even if this were to be considered nothing more that a marketing gimmik, I do not believe it is, it has worked and made me think about it and think it is a good idea.
Nope, you should all be doing 100% No-Bypass Filtration. Do it for the children.Terminator
