Author Topic: HELP!!!!!!!!!!!!!!!!!!!!!  (Read 2736 times)
jersey
« on: October 01, 2005, 04:13:42 pm »
  :'( :'(Just did my 1 month water change. refiled with water, turned power back on and the second pump makes noise but there is no water flow!!!!!!!!!!!!!!!!!! I have a j365 please help :'( thanks
Re: HELP!!!!!!!!!!!!!!!!!!!!!
« Reply #1 on: October 01, 2005, 04:33:05 pm »
Did you fill it through the filter hole? If not - do it that way next time.
It's probably air in the pump. Try loosening the diverter vales and listen for air escaping. My dealer told me this trick - if it doesn't work, I think you need to go to the pump and loosen the drain plug.
jersey
« Reply #2 on: October 01, 2005, 04:46:14 pm »
 :-* :-* :-*Could give you a big fat kiss right now! :-* :-*
It worked!!!! I did fill the right way and had done the one diverter valve like the bible oh I mean manual said but it did not work, when i did the second diverter a bunch of air came out. It took a minute but the water started flowing!!!!!! all is right with the world again. Thank you so much for your help. :-*
« Reply #3 on: October 01, 2005, 05:16:09 pm »
Way to go Vinny.
« Reply #4 on: October 01, 2005, 05:54:56 pm »
I guess I'm a certifiable Spa Tech now ... I got 2 cyber repairs under my belt ... Watch out world!!! :)
cappykat
« Reply #5 on: October 01, 2005, 06:32:32 pm »
Way to go, Vinny!!
2005 Marquis Epic
