Author Topic: Cloudy water  (Read 2685 times)
amat1950
  • Happy Soaker- Tiger River Siberian
Cloudy water
« on: September 23, 2005, 12:48:49 pm »
Hi, I have had the hot tub up and running 2 weeks. Everything was fine unti 2 days ago. It was fine when just my husband and I used it. But then 4 of us used it and the next day Water turned cloudy. :( I shocked it  and now the PH is a little low and TA little low also. We sprayed the filter last night. Still cloudy now. I am bringing a sample to dealer tomorrow and getting filter cleaner.
Any ideas?
Cloudy water
Re: Cloudy water
« Reply #1 on: September 23, 2005, 01:57:01 pm »
Shocked it with what? Do you normally use Dichlor or Bromine?
amat1950
Re: Cloudy water
« Reply #2 on: September 23, 2005, 02:17:54 pm »
I use bromine and the dealer gave me a starter box  of chemicals .This box had Bromine granuals, bottle of Stain and Scale remover, Water clarifier,and little packages of shock. I put a packet of the shock in and let let the filter run for awhile. I have not put the clairfer in yet.
Soakin
Re: Cloudy water
« Reply #3 on: September 23, 2005, 02:30:07 pm »
What are your sanitizer levels?   With cloudy water,  first make sure that the sanitizer residual is adequate, then look at filtration, then try a shock or clarifier.  It can take a day or more for water to clear even after you have addressed the problem correctly.
« Last Edit: September 23, 2005, 02:42:21 pm by Soakin »
amat1950
Re: Cloudy water
« Reply #4 on: September 23, 2005, 02:37:35 pm »
Thank you for the info. I will address one thing at a time. I guess (wrongly) that these worked right away. I will be patient. Have a great weekend  everyone.
amat1950
Re: Cloudy water
« Reply #5 on: September 27, 2005, 12:42:06 pm »
Thank you SOAKIN. Water clear as can be. ;D
Re: Cloudy water
