Author Topic: How long does it take to drain your hot tub?  (Read 13341 times)
Payton3485
  • 2005 Sundance Majesta
« on: September 16, 2005, 05:59:02 pm »
Also, where do you guys drain the tub to? Do you drain it to the sewer or back of your yard?? Just curious, thanks!
Re: How long does it take to drain your hot tub?
« Reply #1 on: September 16, 2005, 06:11:41 pm »
Use a sump pump hose and it should take you 30 min.
If chlorine isn't too high (< 3 PPM) then drain it on your lawn.
hottub.pool_boy
« Reply #2 on: September 16, 2005, 08:42:36 pm »
Garden hose siphon is slow...45mins+-. Swimming pool 1.5" vac hose--done in 10mins.
dalop
  • If its not the Boat Its the Tub!
« Reply #3 on: September 16, 2005, 08:52:04 pm »
I use the hose from my shop vac it takes about 10 min. to siphon out.  I just let it go right onto the lawn.  :)
bulmer4nc
  • Now a Canes Fan.
« Reply #4 on: September 16, 2005, 10:47:30 pm »
Ditto...
We actually start the flow with one of the whirlpool jets so it flows pretty fast and we drain in 15 minutes or so.
Backpains
« Reply #5 on: September 22, 2005, 10:27:03 am »
Draining hot tub is fast and easy...take 5 hoses (hubby has one hose that he has fixed over and over again....so we just take it apart in 5 sections) and siphon the hot tub water into them....and waaa laaaaaa you have a drained hot tub in 15 min!
bp
East_TX_Spa
    • I Love My Spa
« Reply #6 on: September 22, 2005, 10:29:49 am »
I attach a hose to any of our spas equipped with a bottom drain and it takes about 1 hour.  If I'm in a hurry, I use a sump pump and it takes about 10 minutes.
Terminator
« Reply #7 on: September 22, 2005, 11:12:13 am »
Our bottom drain works pretty fast, about 30 minutes.
Drain the water to a pond behind the house.
« Last Edit: September 22, 2005, 11:12:43 am by Brewman »
