Author Topic: PH down  (Read 2497 times)
orlandoguy
  • all you need is tub
PH down
« on: September 18, 2005, 08:25:29 am »
The only issue I seem to wrestle with is getting my ph down.
I have been told that adding more than an ounce at a time of ph down can cause the levels to drop too low and make it difficult to get back at the correct level.
Is this correct?
PH down
vlady
  • 05 Sundance Cameo
Re: PH down
« Reply #1 on: September 18, 2005, 09:33:35 am »
I had a problem with my ph level being too high.  I added ph down every day and it didn't seem to make any difference.
I talked to my dealer and they recommended that I add the recommended dosage of ph down, wait 30 minutes, test it and if it was still high add the recommended dosage of ph down again.  I repeated this every 30 minutes.
It took all day it seemed like but it finally came down and has remained at that same level since.
« Last Edit: September 18, 2005, 10:33:40 am by jnolan »
hottub.pool_boy
Re: PH down
« Reply #2 on: September 18, 2005, 12:50:22 pm »
diddo to vlady
Re: PH down
