Author Topic: Cloudy Water Clear - Now how do I keep it that way  (Read 4556 times)
marks
  • 2005 Beachcomber 580
« on: September 17, 2005, 04:26:33 pm »
Water is good(see cloudy water post). Now how do I keep it good.  How much Dichlor do you guys recommend as an after use shock and how much weekly.  Remember I am also using Nature 2.
TrikkeAddict
  • 2005 Sundance Cameo
Re: Cloudy Water Clear - Now how do I keep it that
« Reply #1 on: September 17, 2005, 05:00:11 pm »
My tub is 450 gallons - I use it twice a day, for at least 30 minutes each time, at a minimum - have ozonator and nature2.  I add 1 teaspoon of dichlor a day, 2 teaspoons if my husband joins me (rare).  I don't shock weekly, more like every 2 weeks and I use 2 tablespoons of dichlor when I shock.
Except for some ph increaser every week or two that's all I put into my tub.  Water has been crystal clear since day one - over two months old now.
Hope this helps.
Susan
hottub.pool_boy
« Reply #2 on: September 17, 2005, 06:02:43 pm »
1\2 teaspoon per 100gals. for regular use (1-2 people up to 20mins), 1 teaspoon per 100gals for heavy use(over 20mins or 3-4 people). That's after each and every use, even if it's twice a day.
Weekly- 1 teaspoon per 100gals. add in the evening when you're done using spa. or wait 4-8 hrs. before re-entering. leave spa cover 1/2 open for 15mins. after weekly dose.
Every third or forth weekly treatment- take clean rag or sponge and wipe super-chlorinated spa water on spa shell above water line and underside of cover. this will eliminate the musty smell when you open the cover prior to using spa.
orlandoguy
  • all you need is tub
« Reply #3 on: September 17, 2005, 07:49:42 pm »
Ever since I began using the bromine floater with the dissolving tablets and adding a few caps of clarifyer each week along with my weekly mps shock, and a little scale and stain remover, remembering to add teaspoons of sanitizer after I wobble out of my tub in a relaxed state is a distant memory along with the cloudy water I saw in the beginning.
My levels are perfect besides an occasional ph down or alk up and even rarer; a bromine boost.
« Reply #4 on: September 17, 2005, 08:36:06 pm »
I have a 400 gallon tub and use 2 teaspoons when I get out which is equivilent to 1/2 teaspoon per 100 gallons that hottub.pool_boy said. I usually soak by myself (talk about having room in a 8'x8' tub) but if someone joins me, I will add 1 or 2 teaspoons per person extra.
As far as shock, I use about 2 - 3 tablespoons. I added 2 tablespoons last night (about 9:30) after 3 of us soaked and I had 3 PPM at 9:00 this morning. I'm sure there weren't any germs left!
I have shocked the water when cloudy and from what I observed my cloudiness wasn't from bacteria, it was from gunk that the filter released because I didn't clean it. I have put 1 tablespoon in my tub and 30 min later the water was still at 5 or so PPM.
hottub.pool_boy
« Reply #5 on: September 17, 2005, 10:26:31 pm »
There are a number of sanitizing systems on the market, and most of them work fine for a lot of people. Orlandoguy- uses bromine tabs, that's great. But Mark said HIS system is chlorine and Nature2. lets not change his system, but help him use the one he's got.
orlandoguy
« Reply #6 on: September 17, 2005, 10:53:18 pm »
Yeah, I definitely wouldn't change his system now, rather tweak it.  I am under them impression that changing now without a complete drain would make things worse anyway.
marks
« Reply #7 on: September 18, 2005, 01:25:07 am »
Your guys are right, I want to stick to Nature 2 and Dichlor.  I added 1 teaspoon after a soak and my chlorine reading was 3 ppm after 20 minutes.  So that should work.  I plan on a weekly shock of 2 tablespoons.  Weekly Clarifier and Stain and Scale inhibitor.
TrikkeAddict
« Reply #8 on: September 18, 2005, 06:54:12 am »
I shocked with 2 tablespoons on Friday night and this morning it's finally down to 3 ppm.  That's why I don't shock very often - keeps me out of the tub too long!!!
« Reply #9 on: September 18, 2005, 07:34:43 am »
This shows you why everyone's tub is different I have a 400 gallon tub too and I need 2 teaspoons to reach that 3 PPM!
« Reply #10 on: September 18, 2005, 12:06:30 pm »
Your one tsp after use and two tblsp for shock seem to be right on target.  I use about one tsp after use for my 485 gal spa.  When I used dichlor to shock, I added two tblspns.  I do not use dichlor alone to shock any more.  I hated to wait to use the spa again and it drove my CYA levels through the roof.
