Author Topic: Water Softener  (Read 2492 times)
marks
  • 2005 Beachcomber 580
Water Softener
« on: September 09, 2005, 11:22:04 pm »
My dealer recommonds adding a water softner to my tub weekly.  Is this a good practice?  I use Nature 2 with Dichloro as my sanitizing system.
Water Softener
Re: Water Softener
« Reply #1 on: September 10, 2005, 10:33:05 am »
What is the water softner product? There are products that give the water a "soft feel" without lowering the calcium hardness reading and as long as you're maintaining a 150-200 ppm reading of CH then you're fine.
Soft water is not good for a spa. It will be scale forming and cause foam.
marks
Re: Water Softener
« Reply #2 on: September 10, 2005, 10:40:18 am »
It is Beachcomber Soft, he has me adding 2 3/4 oz a week in a 400 gallon tub.  The lable claims:
 Gives water a silky, smooth feeling
 Prevents pH bounce
 Promotes amore stable water balance
No ingrediant list, but the warning say contains boric acid.
Not sure how to measure calcium hardness, both my pH and alkalinity reading are fine.
Re: Water Softener
« Reply #3 on: September 10, 2005, 11:19:11 am »
Beachcomber's product "soft" falls into the catagory of water quality products that don't effect the CH readings. This reading should be tested at your dealer monthly.
Nice product.
Rayman
Re: Water Softener
« Reply #4 on: September 10, 2005, 06:11:18 pm »
I use "SOFT" from Beachcomber and it makes the water feel soft and smell like green apples.  And Ditto to what Steve said.
Ray
Re: Water Softener
