Author Topic: Wiring  (Read 2235 times)
bsorok
Wiring
« on: September 08, 2005, 03:01:15 pm »
I am getting an Optima this week.
I know they have openings for wiring on the sides.
One guy mentioned that his wiring goes straight up from underneath.
Any ideas on which is better. I assume if the tub needs to be moved, escess wiring from the side will provide more room?
Wiring
Re: Wiring
« Reply #1 on: September 08, 2005, 03:35:47 pm »
Your choice.  The Optima should have wiring grommets on both sides, adjacent to the side with the main controls.  You can also come up thru the bottom.
I went the lazy way and ran my conduit above ground- I didn't feel like trenching.  Underneath makes for a neater less cluttered install.  If you leave enough clearance around the spa most service should be done without needing to move the spa, I'd think.
Base your decision on what you like better, or want to pay for.  If you're hiring this out, get advice of electricians for cost of one way vs the other.  I suspect that trenching will add to your costs.
You'll need to plan this out before installing your concrete base.
« Last Edit: September 08, 2005, 03:37:08 pm by Brewman »
velocity23
  • If it ain't broke...break it
Re: Wiring
« Reply #2 on: September 09, 2005, 10:41:29 am »
My Optima sits on an elevated deck so that was an easy decision. I came up from the bottom to give it a clean look. If its on a concrete pad then I would probably go the route Brew did if I was doing it myself. As far as excess wiring in case the tub needs to be moved shouldn't be an issue IMO, so I wouldn't base my decision on that. But it all comes down to what you want. Good luck in your decision.
Re: Wiring
