Author Topic: Survey..how hot is your tub......  (Read 9899 times)
Backpains
« on: August 19, 2005, 04:04:23 pm »
in the winter..for all you that have had your tubs for a bit now..How high do you all normally go in the winter time?
I was thinking about this..right now if I go any higher than 99 I'm toasted within 15 min..can't even make it for 15 min at 100...so I was kinda thinking on what temp to keep it in the winter time...so...amuse me gang!
windsurfdog
Re: Survey..how hot is your tub......
« Reply #1 on: August 19, 2005, 04:21:22 pm »
96 in summer--it usually hovers around 97-99
99 in winter--it's always 99 then...... 8)
« Reply #2 on: August 19, 2005, 04:58:20 pm »
102 in the summer.
102 in the winter.
When my spa was new, I kept it at 98 in summer and 100 in winter.  Now I can't bear the thought of less than 102.
vlady
  • 05 Sundance Cameo
« Reply #3 on: August 19, 2005, 05:19:36 pm »
Mine will be cranked to the max.  I'm a southern gal and I don't like the cold.
« Reply #4 on: August 19, 2005, 05:24:33 pm »
Planning on at least 102 in winter.
orlandoguy
  • all you need is tub
« Reply #5 on: August 19, 2005, 05:27:04 pm »
Mine never goes below 102, and that's in Florida, where the heat index makes it feel like 106 all Summer.  It is a hot tub and should be hot.
TrikkeAddict
  • 2005 Sundance Cameo
« Reply #6 on: August 19, 2005, 06:03:23 pm »
101 is what I enjoy in the winter
PaulMc
  • 2005 Sundance Majesta and lovin' it.
« Reply #7 on: August 19, 2005, 06:06:21 pm »
  We're just under a month into ours so no winter experience yet, but we run at 101 now and plan on 103 when the snow flies.   paul
Owner, Sundance Majesta , July '05, Ontario Canada
CalicoskiesNC
« Reply #8 on: August 19, 2005, 06:53:59 pm »
94 in summer about 100 in winter
Haynes
  • 2005 Down East Cape Cod/ Monongahela, PA
« Reply #9 on: August 19, 2005, 08:44:46 pm »
102 in the summer but on hot days it creeps up to 104-105.  On cool nights we like 104.  You get use to it be real hot after you had your tub a while.  The hotter the better .It  helps the aches and pains.
obi wan
  • you're just jealous the voices only talk to ME!
« Reply #10 on: August 19, 2005, 10:29:16 pm »
keep heater at 99 so that means 101-102 in the summer. keep it at 102-103 in the winter.
i must agree with earlier post. for a cool refreshing dip, get in the pool. a hot tub should be hot.....
NE-Phil
  • Marquis Reward '05
« Reply #11 on: August 19, 2005, 11:13:00 pm »
...for a cool refreshing dip, get in the pool. a hot tub should be hot.....
I don't have a pool or even room for a pool. ;D
I've been keeping mine at 91. It's refreshing.  I plan for the winter time to have it up to 101.
Phil
Rachel
  • Four Winds Maverick I
« Reply #12 on: August 19, 2005, 11:54:40 pm »
First timer and we live in the south for now. Ours is set at 100 degrees
windsurfdog
« Reply #13 on: August 20, 2005, 07:00:05 am »
And obi wan said:
....a hot tub should be hot.....
Thank goodness spa cops don't exist....;D
Payton3485
« Reply #14 on: August 20, 2005, 08:00:09 am »
I am am 101 in the summer and will use 101 or 102 in the winter.
