Author Topic: Diplomat SPA  (Read 1828 times)
Weston
Diplomat SPA
« on: August 31, 2005, 11:26:44 pm »
This is going to be my first Hut Tub. I saw a Diplomat from Dimension One and I need some advice about the right price and performance.
Thank you for the feed back! ??? ?
Diplomat SPA
stl-rex
  • Arctic Tundra Owner
Re: Diplomat SPA
« Reply #1 on: August 31, 2005, 11:33:28 pm »
My recent quote was for $7800 - $8000 including cover lifter and steps, del and some start-up chems.  I've seen lower numbers posted on this forum and higher also.  I did not wet test it.  Tested another D1 model that had water in it and it did not fit us, but I thought the jets were fine.  It appears to be a quality product and gets favorable "press" here.  Coleman and Arctic also make double loungers if that is what you are seeking.
HotTubMan
  • My 2.1 cents, eh
Re: Diplomat SPA
« Reply #2 on: September 01, 2005, 12:49:31 pm »
Hydropool also makes a dual lounger tub. The loungers are side by side and can be used to sit facing eachother or in the same direction.
As for the Diplomat, it is an excellent spa with good power.
Re: Diplomat SPA
