Author Topic: Marquis or Caldera??  (Read 13070 times)
Wolf_Racer
« on: August 21, 2005, 12:57:44 am »
This is a great site, and glad I found it. Lots of great info.  I have started my spa search. I have visited most of the spa dealers in my area and wet tested, Caldera, Hotsprings, Marquis, Sundance and Artesian. Looked at Wind River and CalSpa but not wet tested.
I have narrowed it down to either the Marquis Epic or the Caldera Geneva. Artesian seems like a step below all others I have listed above.
I agree with a lot on this review for both of these models (and other models I have tried):
http://www.whatsthebest-hottub.com/cgi-bin/yabb/YaBB.pl?board=wtb-hottub;action=display;num=1124071622
A few things to add:
Marquis:
- Tri-zone might be better the way they do it as you can focus on certain areas better.  I can see that you cannot have all the jets on in one section. Was a little hard to understand at first but after about 10 minutes I understood and can see advantages
- Better for small kids due to the variety and higher seats
- Like the deep seats and their variety for others
- Agree the jets are not as nice as other brands. More durable probably. Can buy fancier jets
- Quality appears to be good
- Wonder how main pump will last since no smaller 24 hour pump. Salesman says it will last and is low energy
Caldera:
- Very powerful jets. Too powerful on highest settings really, but that can be adjusted
- Wife loves the foot hold to keep her from floating away. I liked that too. That is almost the deciding factor for her, Funny
- Jets variety better
- Like the lounge and the foot holds in it
- Seat with neck cusion that goes around your neck was very comfortable and reduced spray when jets were on.
So I could go with either.  If you have any opinions or have compared these two models, please post your thoughts.
I am getting quoted $8536 (for cash) plus tax on the Marquis that includes everything (lift, cover, initial chems, delivery, step, setup).
I am getting quoted $9120 (cash price) + tax on the Caldera Geneva. This includes all in the Marquis plus a sub panel 230v (they have a little different wiring on the caldera with two breakers) so would save some $$ on the electrician.
I am located in the Denver, Colorado area.
Do these prices seem reasonable? I am thinking the Marquis price a little high based on other posts on these foums. Not sure why someone in Pittsburg could get this spa at $7900 but Denver (closer to Oregon, where they are built) is $600 more.  I have tried to negotiate with Marquis, but they seem firm.
Thoughts on any of this, especially pricing.  Do spa dealers negotiate?  They all tell me now is the best time to buy the spa as this is the lower prices of the season. Not sure I buy that.
« Last Edit: August 21, 2005, 01:10:33 am by Wolf_Racer »
TTyacke
  • Marquis Epic Owner
Re: Marquis or Caldera??
« Reply #1 on: August 21, 2005, 01:23:51 am »
I live in Vancouver, WA (which is about 2 hours from where the Marquis Spas are built) and I got a great deal on the Epic at $8,500, with the same package you listed.  The price you were quoted sounds very good.  The Caldera seems a little high as you could get the HS version for that price.  Both are great tubs, but the Epic will soon be selling in the $9,000-$10,000 range in the next year.
stuart
« Reply #2 on: August 21, 2005, 06:32:38 am »
Both are good spas and carried by good dealers there….
The price for the Epic is about $800 less than the rest of the dealers in your region with the options you’re getting!
I have worked with both dealers there in Denver and can say with all honesty that both are above average....The Marquis dealer has a better service record but neither is bad. The Marquis Dealer has also sold one brand more consistent than any other dealership in the state.
I find this a strange statement? Is this an observation of aesthetics or actual function? I think if you had those jets side by side with any other jet in the industry you would find them in the upper end...?
The 24 Hr Circ pumps have a greater fail rate than the 2 speed system per capita...A 24 hour circ pump draws .98 amps and runs 24 hours moving every drop of water in the spa through the filter around 20 times per day. The pump system that Marquis now has draws 1.2 amps on the filter setting and moves every drop of water through the filter over 60 times a day.
Marquis was a huge proponent of 24 hour circ pumps many years ago and found that it made more sense to them that you could accomplish more filtration with the same or less power cost and eliminate an entire addition pump and system to fail!
I believe you will also get a more inclusive owners protection plan or warranty with the Marquis...More components covered, less exclusions and transferable if you sell the spa. Marquis gives you 2 years longer on the cabinet warranty, 2 years longer on the plumbing warranty and does not exclude things like fuses (remember you are in one of the higher lightning activity areas in the nation and power surges are an issue) in addition to giving you a warranty on the ozone system that Caldera specifically excludes.
The Epic should give you better maintenance reminders.
The Caldera is single filter vs the Marquis dual filters.
The Marquis will give you more of the desired “corner seating” with the filters out of the corner.
The DuraBase on the Marquis has a much greater protection capability than the pressure treated wood base covered just on the bottom with plastic that the Caldera uses. In addition the DuraBase is backed with a Galvanized steel support system and a longer warranty (I don’t believe Caldera has a warranty on their base…?).
Hope this helps…I do think you would be happy overall with either.
Wolf_Racer
« Reply #3 on: August 21, 2005, 09:46:59 am »
Stuart,
You sound just like the Marquis dealer I met with! Are you sure you are not him?? ;D
Seriously, thanks for the info. I agree both dealers seem to be pretty good.
What I meant about the jets is the Marquis do not have as many adjustments or features as the caldera or most other spas I have looked at.  They look stronger and I think will last longer however.
You have a few other very good points.
Any other folks have opinions about pricing? Anyone is Colorado get better pricing than what I have been quoted?
What is annoying a little is the Marquis deal said this price was only good Saturday and Sunday, which is a red flag to me. I am pretty sure they will honor is this next week as well.
« Reply #4 on: August 21, 2005, 03:13:17 pm »
Both are very good choices. Assuming both dealers seem like they'll service you well, I'd wet test both and go with whichever fits/feels best.
Duffman
« Reply #5 on: August 21, 2005, 03:51:16 pm »
Your quote on the Marquis Epic was $50 less than the deal I was offered so it sounds good. As for the Caldera, the Niagara is one of the front runners on my list. I made it clear that I was evaluating a number of spas and wanted his best offer; no haggling really. He came back with $8900 for the typical spa pacage including steps, cover lifter, GFCI panel, chem pack, delivery, setup package. The quote you received seems a little high
« Last Edit: August 21, 2005, 07:29:03 pm by Duffman »
Duffman
« Reply #6 on: August 21, 2005, 07:49:46 pm »
After going through this process before and witnessing it many times I can assure you that your dealer is just doing his/her job as a salesperson by giving you every reason to put a deposit down sooner than later. However, you can certainly negotiate within reason. Dealer's are not going to sell without making a profit but they do have significant room for maneuver.
it is my understanding from talking to a couple dealers on this subject that the spas cost them the same amount for a given year no matter what month it is. However, If you are time pressured where you have to take one of the spas in stock at the store, your barganing position will be diminished and you may not get as good of a deal.
If you are clear that you have done your research, are definitely going to buy, but are willing to wait for the right price, most dealers I have talked with go into their office and will give you their "best offer". They know you have a couple other spa brands in mind and don't want you walking out of the store.  At that point you should really know your facts before trying to haggle further on the spa. Another option is to negotiate for free or discounted accessories you will need (e.g., extra filters, cover lifter, GCFI panel, etc.) if the deal is still not to your liking.
Best of luck with your negotiations.
Mendocino101
« Reply #7 on: August 21, 2005, 08:12:41 pm »
Simply incorrect all spas  have many petroleum by products in them and as the cost of oil continues to rise spa prices have gone up along with the shipping costs.
« Last Edit: August 22, 2005, 12:27:57 am by Mendocino101 »
Bill_Stevenson
  • Hot Spring Envoy
« Reply #8 on: August 21, 2005, 09:46:39 pm »
Well I have to tell you that you and I see these two spas almost exactly alike.  I went with the Caldera Geneva Utopia and the tie breaker was the little bump on the floor.  I still miss my Caldera.  For those who think the HS is better I've got news for you - it ain't.  But like you, I could have been happy with the Marquis too.  Truth to tell, though, that Caldera still sings to me.  I really miss it.
Regards,
Bill
Mendocino101
« Reply #9 on: August 21, 2005, 10:25:49 pm »
Regards,
Bill
It is really interesting how 2 people can feel about a spa so differently ....neither is right or wrong, but unlike Bill .....After placing a deposit on the same Caldera...I wet tested it and knew it was not for me....and because of this and my continued shopping....I wound up becoming a Marquis dealer .....so as you can see wet test when ever possible ....both are nice .....but the Caldera would not work for me but might for you....  :D .....
Sunny
« Reply #10 on: August 22, 2005, 07:14:18 am »
I own the Caldera Niagara.  The foot bump is key to my enjoyment of my tub.  I learned this by wet testing & by the comments on this board.
I agree selection is a very personal thing.
poopsy
« Reply #11 on: August 22, 2005, 02:46:28 pm »
i like the outside lights on the caldera spas..they are a nice feature. I am considering a caldera tahitian utopia- sundance altaman/cameo or ultima-  artesian dove or marquis....so many choices..i have yet to get out of a tub and say wow..thats it..
poopsy
« Reply #12 on: August 22, 2005, 02:47:20 pm »
I TOO AM IN DENVER..AND THE COMPETITION IS FIERCE,,,I AM LOOKING FOR A 12 MONTH NO INTREST /NO PAYMENT OPTION AS WELL..
nicksd
« Reply #13 on: August 22, 2005, 08:16:41 pm »
I love this forum, I am so greatful that I have learned so much from all of you.  My wife and I have just ordered a 2005 Marquis Epic w/out stereo from one and only dealer in San Diego,CA for $7900.00 (the price includes tax of 7.75%, delivery, lift, cover, step, start up chem and crane service). I understand that price varies from city to city but I still hope my info helps.  Good luck.
Wolf_Racer
« Reply #14 on: August 22, 2005, 11:28:30 pm »
Wow, $7900 sounds like a great deal. I read on the forum somewhere else that someone in Pittsburg got around $7900 too. Not sure why Denver is that much higher.
poopsy: Caldera and Hotsprings (IHT) and Marquis both have 12 month no interest now. If you pay cash IHT will give you 5% off and Marquis something like 3% off.  I personally did not like the dealer for Artesian at Park Meadows. Did not seem like they knew their stuff and only have been the Artesian dealer for 1 year. IMO the Artesian is lower quality hot tub than Caldera and Marquis. But, my Neighbor has had a artesian for 3 years and had zero problems with it. It is outside uncovered too.
