Author Topic: Nasty yellow scum line-please help!  (Read 12575 times)
mrskansas
« on: August 14, 2005, 09:43:15 pm »
Ok, I've had my Marquis for about a month, and now today I open the cover, and there is what looks like yellowish cottage cheese around the water line & skimmer, along with some foam.  I wiped off the yellow stuff and turned the jets on, only to find TONS of foam, and the reappearance of the yellow cottage cheese.  I am freaked out because I have never had a foaming problem, and there are only two of us who use the tub.  All chemical checks are ok.
Any ideas?  Water is also cloudy-which is new.
Not sure what to do.  I can drain, but if I don't know what caused it, I can't prevent it from happening again  :'(
Please help the newbie!
Thank you!
Haynes
  • 2005 Down East Cape Cod/ Monongahela, PA
Re: Nasty yellow scum line-please help!
« Reply #1 on: August 15, 2005, 03:14:15 am »
Clean your filter.  Make sure your filter cycle is on.
« Reply #2 on: August 15, 2005, 08:46:38 am »
Mrs Kansas, this isn't unusual for a newbie, I think everyone sees it at least once.  As mentioned if you see it on the waterline, its on the filters.   Shock heavily, rinse the filters and take a look at when how often you add santizier.
Also think about who is wearing too much body oil and stuff.
« Last Edit: August 15, 2005, 08:49:49 am by wmccall »
