Author Topic: Pump Seal  (Read 3804 times)
countryboy
  • soak it in cider
Pump Seal
« on: July 11, 2005, 03:17:08 pm »
What will cause a Pump seal to fail? water chemistry is in the limits. There is a white crust around the seal and in the pan under the pump. Its an itermiten leak.
Pump Seal
Re: Pump Seal
« Reply #1 on: July 11, 2005, 04:14:48 pm »
How old is it?
SDguy
  • Where do they get these names for spas?
Re: Pump Seal
« Reply #2 on: July 11, 2005, 04:20:03 pm »
The white stuff is probably minerals (calcium). That would help make it brittle and thus causing it to leak. Make sure your using a water softenner or some type of scale control in the water.
J._McD
Re: Pump Seal
« Reply #3 on: July 11, 2005, 05:33:27 pm »
several things will cause a pump seal to leak.  1 = Friction, running the pump for a period of time without water, such as an air lock creats heat by friction.  2 = water chemistry and acidic chemicals.
Should you discover a pump seal leak it is less than a $100 repair, if neglected it becomes a $500 repair.
The white salts are residual chemicals from the water the leaked through and evaporated leaving the chemical and mineral content behind as evidence.
Re: Pump Seal
« Reply #4 on: July 11, 2005, 05:58:42 pm »
I agree.
Most common cause of this failure is low pH or keeping a floating feeder in the skimmer.
countryboy
  • soak it in cider
Re: Pump Seal
« Reply #5 on: July 12, 2005, 06:52:32 am »
PH, Alk are all in the limits, no floater, Hardness is where is should be. The tube is a year old. Never ran with out water or bleeding system first. Maybe just a bad seal from factory?
HotTubMan
  • My 2.1 cents, eh
Re: Pump Seal
« Reply #6 on: July 12, 2005, 09:43:35 am »
Very possible. Get it fixed before you corrode the bearings or worse.
countryboy
  • soak it in cider
Re: Pump Seal
« Reply #7 on: July 12, 2005, 11:02:36 am »
Already fixed, they installed a new pump not just the seal.
jsimo7
  • luvin hot wet nights
Re: Pump Seal
« Reply #8 on: July 12, 2005, 11:28:43 am »
Good deal that is is fixed, Replacing the entire pump is good for you to insure no problems later because of this defect
Re: Pump Seal
