Author Topic: Hot Springs water temp in plumbing  (Read 2473 times)
jsimo7
  • luvin hot wet nights
« on: July 11, 2005, 02:44:42 pm »
Does the HS cir pump, pump water through the plumbing, Chas wrote  "The running circ pump keeps the water equal temp all over, including in the plumbing " My Envoy sends cool water from the jets and waterfall when the pumps are started for the first few seconds. Do I have a problem that  I need to correct before the tub goes through the 1st winter?? I asked this in another thread but thought I should post it under this subject so all HS experts will see it.
georgiapeach
Re: Hot Springs water temp in plumbing
« Reply #1 on: July 11, 2005, 03:00:39 pm »
My Grandee does the same thing.  I didn't think anything about it...hhmmmmm
« Reply #2 on: July 11, 2005, 03:23:00 pm »
My tub does the same. I know from experience that even in the dead of winter the air inside the cabinet stays above freezing.
jsimo7
« Reply #3 on: July 11, 2005, 03:27:56 pm »
Thanks, I didn't know if mine was different from others
tonyp
  • Soaking in a HS Envoy!
« Reply #4 on: July 11, 2005, 03:59:23 pm »
My Envoy is the same.  Just start the jets before you get in.
