Author Topic: cleaning out sand/dirt  (Read 8512 times)
Gman
« on: July 06, 2005, 08:08:41 pm »
What do others use to clean out dirt or sand that enters the spa on your feet?  I have a pool near by and the deck recently had quite a bit of sand on it -- so a fair amount has transferred into the spa - even though I put a bucket at the bottom of the stairs with water in it  :-/
« Last Edit: July 06, 2005, 08:09:15 pm by Gman »
Backpains
Re: cleaning out sand/dirt
« Reply #1 on: July 06, 2005, 08:12:53 pm »
we usually make sure our feet are very clean before we get in the tub...usually have a bucket of water beside the tub and we also have extra towels out there
« Reply #2 on: July 06, 2005, 08:37:44 pm »
The best suggestion I can come up with is to trade it in on a Hydropool spa that comes standard with a built in floor vacuum to remove this sort of debris! ;)
Either that or http://www.rhtubs.com/store/vacuumes.htm
J._McD
« Reply #3 on: July 06, 2005, 08:55:35 pm »
Now Steve, I think that was a commercial.  ;D
Wet feet take MORE sand in.  A mat, towel or a rug on the top step could be helpful.
« Reply #4 on: July 06, 2005, 09:43:37 pm »
I was going for more of an infomercial... :-/  ;)
I guess a towel on the step would work too... ;D
« Reply #5 on: July 07, 2005, 01:10:24 am »
I like the Paradise Vac the best - one moving part, no pumping, non-electric.
Next to that, a simple siphon works great. Get a PVC fitting to connect a short length of pvc pipe to a short hose and you can remove the sand from the tub easily.
glue a section of 3/4" pvc pipe in one end, and thread a garden hose to the other end and you have a great 'econo vac.'
« Reply #6 on: July 07, 2005, 09:21:55 am »
I have this problem too. Being pro-active with preventative steps  to stop sand from getting into the tub is a must. However, once the sand is in there, I find it a pain.
I puchased a Polaris Spa Wand from my dealer. Simply put, it's a long tube with nozzles that uses suction from drawing the long handle in and out. It sucks up the sand accumulated in the spa. It has a metal mesh screen filter doo-hickey to trap the sand in the wand and not spit it back out of the tube.
It works pretty good. I'm glad I have it.
They sell it for $55 and have free shipping: (Dealer plug) http://www.nespas.com/spas-5.pdf
And I've seen them on E-bay for about $40.
« Last Edit: July 07, 2005, 09:23:04 am by drewstar »
Ruby
  • Marquis Epic
« Reply #7 on: July 07, 2005, 10:02:20 am »
I've read that a turkey baster will work
Minnesota Consumer
Been soaking since 7/2004
Backpains
« Reply #8 on: July 07, 2005, 11:36:22 am »
Oh....and we are also installing indoor outdoor carpet this month
Ritz
  • Vanguard 2004
« Reply #9 on: July 07, 2005, 12:51:38 pm »
We use a little hand-held gizmo called a Grit Gitter - or something like that.  We got ours at the dealer, but I've seen others post that it's less expensive on-line at Doc's site...
r100rs
« Reply #10 on: July 07, 2005, 04:10:56 pm »
I make my kids fish them out.  99% chance they brought it into the tub - 100% chance they'll take it out!  ;D  ;D
but only while they're in the tub
r100rs
« Reply #11 on: July 07, 2005, 04:26:13 pm »
fish out sand by hand? That's sounds tough!
course it's better than holding them by the ankles dipping them in the tub upside down and telling them to "Ok Suck!"
