Author Topic: Not Recommended as Sanitizers ???  (Read 2573 times)
TALKCalgary.com
« on: June 21, 2005, 01:02:01 am »
Good evening learned hot tub dwellers!
Does one know why Sodium Hypochloride (liquid) or
Calcium Hypochloride (granular) are not recommended for use in hot tubs?
« Last Edit: June 21, 2005, 01:06:19 am by TALKCalgary.com »
Wisoki
  • YEEEEEEhaw
Re: Not Recommended as Sanitizers ???
« Reply #1 on: June 21, 2005, 10:55:47 am »
They both can etch the acrylic surface if your spa. Notice I said "can" not will. Also, the liquid being heavier than the water will settle and be drawn directly into the pumps when activated causing premature failure. Yeah, I know, you will only add it with the jets on. For the first 6 months to a year. After that, you'll think to hell with it I gotta get to work and just toss the stuff in. Eliminate that eventuality and use the prescribed chemicals.
HotTubMan
  • My 2.1 cents, eh
« Reply #2 on: June 21, 2005, 10:59:00 am »
Sodium Hypochloride also is made from SALT. Salt is not good for jets (with bearings) or heaters.
