Author Topic: Filling your spa?  (Read 2504 times)
Payton3485
  • 2005 Sundance Majesta
Filling your spa?
« on: May 31, 2005, 02:42:43 pm »
How often do you guys and gals need to fill your spa so that it is at the optimum level (i.e. Water level above the highest jets) ? I was just wondering how often you guys have to add a little water to the spa in between a total drain and refill. I would assume this would be water lost to condensation as well as people in and out of the spa. Thanks for your help!
Filling your spa?
Bill_Stevenson
  • Hot Spring Envoy
Re: Filling your spa?
« Reply #1 on: May 31, 2005, 02:47:42 pm »
About once every 2 weeks.
« Reply #2 on: May 31, 2005, 02:55:13 pm »
Very similar to Bill. Every 10 days - 2 weeks. The large majority of your water loss is due to bathers getting out of the spa.
Payton3485
« Reply #3 on: May 31, 2005, 02:58:42 pm »
Thanks for the quick replys ;D. So do you guys just fill the spa directly with a garden hose? Does this throw off your water chemistry at all? Thanks again!
« Reply #4 on: May 31, 2005, 03:49:12 pm »
Every two weeks I check it.  It seems to need it more in cold winter months, but I have no scientific proof of that.  Its good to check.  The one time I had a leak I knew it was going down faster than normal so I knew to look for problems.
Drewski
« Reply #5 on: May 31, 2005, 04:23:13 pm »
Well, let's see. Every few days?
Why?
Drewski
8)
« Reply #6 on: May 31, 2005, 04:30:42 pm »
Yep...the garden hose. Based on the volume of water, adding a couple of inches won't effect the balance in most cases but it depends on your source water and the amount you are filling. Leave it for a day or so after topping it up and retest to be sure.
Great pic Drewski! That's what it's allllll about!
« Last Edit: May 31, 2005, 04:32:27 pm by Steve »
Payton3485
« Reply #7 on: May 31, 2005, 05:18:49 pm »
Thanks Steve!! That is what I thought.
