Author Topic: how do you insert pictures  (Read 2878 times)
grumpy
« on: September 06, 2006, 09:37:04 am »
How do you insert pictures? :(
cooltoy2000
  • Go Flames Go!!!
Re: how do you insert pictures
« Reply #1 on: September 06, 2006, 12:01:30 pm »
Find a picture you want to post (it has to be hosted on a website, will not work if it is on your hard drive). Right click on the picture and select PROPERTIES from the drop down menu. Copy the URL of the picture and then click on the little "image" button , then paste the URL between the img tags.
PS. Some websites do not allow you to link to their images as it uses their bandwidth.
PSS. If you need to post a picture fron your hard drive, it first needs to be hosted on the web, try PhotoBucket. There are other similar image hosting websites.
« Last Edit: September 06, 2006, 12:03:56 pm by cooltoy2000 »
grumpy
« Reply #2 on: September 06, 2006, 03:30:35 pm »
Thank You I'll give that a try
« Reply #3 on: September 06, 2006, 04:18:43 pm »
By definition, shouldn't this be moved to the beating a dead horse section?
« Last Edit: September 06, 2006, 04:19:26 pm by Spatech_tuo »
