Author Topic: Enough Deck Strength & Support??  (Read 3957 times)
Neohcouple
« on: May 08, 2005, 02:05:44 pm »
I am having my HS Vanguard delivered next week.  I am in the process of starting the deck tomorrow.  Just wanted to see & make sure that I have enough support.
The deck is 27'x16' & I am using plastic deck boards.  It will no more than 30" off the ground.  There are 9 posts (4x4x8) cemented in the ground 44-48" inches down(3 posts in each row).  Attached to these posts are 2-2x8's on each row.  On top of these are 2x8 stringers spaced 12"o.c.  Hot Springs says that the tub will weigh approximately 5,039 pounds when filled with water (400 gallons) & 5-6 people in it.
Any thoughts or opinions??  Thanks
nicker
Re: Enough Deck Strength & Support??
« Reply #1 on: May 09, 2005, 08:59:54 am »
This is a question that only a structural person can tell you.   Its allot of weight on a deck when you consider the tub, water, people in it, movement and what ever other deck items you will have on it.   I think you are on the right track.   How ever I would personnally change a few items.   My deck is about 24" off the ground.   I used cement pillars with rebar in them and then the set a bolt in the center of each on and used the deck hangers to put my beams in. Then put my joists on top on 12" on center.  The things I would change is I wouldn't cement the 4x4 in the ground, I would pour footings/pillars and use the galvanized brackets to hold your beams in place.  For decks its nice to avoid any wood contact with the ground surface.   I would also beef up the beams to 2x10 or 2x12 doubled up.  Its just a peice of mind knowing your deck is going to last.
Good luck
windsurfdog
« Reply #2 on: May 09, 2005, 12:20:52 pm »
Our deck, which is 8' off grade, is way overbuilt but I'm happy it is......8x8 pilings in 2' diameter concrete 4' deep topped with 3 2x12's topped with 2x10's on 8" centers under the tub and 16" centers under the rest of the deck.  The decking is 2x6's.  This baby doesn't move one iota. 8)
Orthofunk
« Reply #3 on: May 09, 2005, 12:22:58 pm »
I just had a deck built to support the Sundance Maxxus.  It is 12'X16' and about 24" off the ground.
A structural engineer OK'd the following plan:
6 6X6 posts set in concrete with double 2X10 beams
2X10 stringers at 16" on center.
The deck builder notched out the posts where the 2X10 beams go for added support.
