Author Topic: hot tub bases  (Read 2623 times)
jss944
hot tub bases
« on: April 30, 2005, 01:16:25 pm »
How big of a base should I put undermy hot tub?
It is 83x76.
Also any good suggestions for easy good bases?
Jaymi
hot tub bases
hottubber
Re: hot tub bases
« Reply #1 on: April 30, 2005, 03:46:47 pm »
Make sure that when you do your base, regardless of what it is, don't forget the steps. They also should be on a firm, solid base.
I would do 1 1/2 feet more in each dimension, that gives you 3/4 of a foot all around the perimeter so no grass or weeds grows up next to the spa cabinet. It also looks very clean when trimmed off that way.
good luck,
hottubbe... ;D
jss944
Re: hot tub bases
« Reply #2 on: April 30, 2005, 10:17:07 pm »
Thanks for your info!!
We are going to be building ta deck around the tub, so I don't have to worry about the step or the grass.
Thank again! Jaymi
Re: hot tub bases
« Reply #3 on: April 30, 2005, 10:51:24 pm »
I doing the same also. I definitely would build the base larger than the tub so that you have room for adjustments - you don't want any part of the tub off the base.
I'm getting a 92" x 92" tub and building a 8' x 8' deck for it to sit on it. Just a FYI as you build the deck think about access to the motors and electronics underneath. I learned that from the people on here as I was designing my main deck.
Good luck!
Re: hot tub bases
