I love this comment " Some would argue they should be priced less because there are debates on whether their engineering approach works" What engineering might that be? I guess I should have argued that when I was purchasing the tub.
Now, if Arctic tested the tubs, and did not use the standard grade covers across all tubs (smaller thickness than what would come standard), then I would say that not only is it misleading, but grounds for a lawsuit.
I think I found the test by the ARC on the Arctic website. It might have been me but I could not see any information on the type of cover used on the spa's.I did find it funny on the cost comparison download....anyone have any clue on which "foam filled spa" was tested?Not slamming Arctic at all just would like to know which "foam filled" brand they used.
This discussion is pretty hot right now, not sure if I want to throw gas on the flames or not......well here goes:Several manufacturers have comissioned 3rd parties to study the energy efficiency of their brand...including both that I sell. I for one put little stock in these. The 3rd party was paid to do the study by one manufacturer. Whether it is in the contract or not, the desired results are implied and delivered by the 3rd party. I would be more likely to beleive a study that was either commission by all of the manufacturers combined (never going to happen) or one that was conducted by the government or a 3rd party that does not profit from conducting the study in any way.
To use an "independent study" with skewded results to claim superiority over several other brands is a poor sales tactic that lends to the true nature of the sales and marketing department. Who cares if it's independent if the comparison is not fair.
James,I was referring to the other study that you can download from your site that was conducted in Loveland Colorado. There is a "foam filled" spa that was run against the Arctic. No mention as to what name brand or type of spa that the study was done against....just "foam filled".Regards,Mike
This last item is one that really burns me. Does anyone really beleive it is wise to simply level the dirt in your back yard and place a spa there? What if the ground shifts (around here that happens every fall and spring)? The forever floor has its advantages, but I feel it is misleading to suggest that one needn't build a proper base, concrete or otherwise.
Though I believe that's possible James, would a spa be covered under your warranty if a customer did the same and expereinced damage? Do you suggest that putting a spa on your grass is an exceptable installation?Do you know of other brands which construct their spas to withstand this same application or do you feel this is limited to an Arctic? What % of manufactures could offer the same "feature" to their customers do you believe?Steve
Can anyone direct me to a link to the test??I would like to read that for myself.I do have to state this though....I have heard some things from "number one" dealers that are outright "lies" as well to sell a tub.I would like to see the results of the test personally as posted in a link so that I can wade through the rhetoric myself.Thanks if you could be so kind.Regards, :-/
If the covers were not all the same thickness, then the test results were skewed. Yes the test involved standard covers. But the Arctic has a 1 sometimes 2 inch thicker cover than all the rest. To claim superior energy effieciency because of a thicker cover IS decieving the public, shame, shame. Some of us can see right through it.
